Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1927037members
1239445discussions
Community Activity
connetion events in FMC
Hi Dears,in our company we have FMC\FTD but the logs (connection event) were saved for almost 1 week back only.i have been checked the limitation as the below tableConnection eventsSecurity Intelligence events50 million (FMC Virtual, FMC750) 100 mill...
khaled-jd by Level 1
  • 49 Views
  • 1 replies
abandoned call to agent timer
We have many calls consider as abandoned due to caller hang-up, how I can make the calls consider abandoned if ring on agent more than 10sec, and if the calls ring on agent less than 10sec not consider as abandoned, because many calls hang-up after r...
matee by Level 1
  • 103 Views
  • 2 replies
HSRP Not Establishing but L2 Connectivity Verified
Replacing some old cisco routers with 8500's running 17.9.4a.  They are connected to a Nexus 7K, on the same card.  The routers can ping one another and establish BGP but they will not establish the HSRP adjacently across the 7K.  If the 8500's are c...
mac flapping
Apr 16 04:14:35.390: %SW_MATM-4-MACFLAP_NOTIF: Host 001b.0907.fe0e in vlan 11 is flapping between port Gi1/1/1 and port Gi1/1/2Apr 16 04:14:35.390: %SW_MATM-4-MACFLAP_NOTIF: Host 001b.0907.fe0e in vlan 11 is flapping between port Gi1/1/1 and port Gi1...
Access Points show 0 clients
DNAC Installed Version: 2.3.5.5-70026Cisco Catalyst 9800-80 17.9.4aAXE 9120i, 9130We have about 10 employees in our office using DNAC at varying role assignment levels.I am Super-Administrator and handle most of the the WIFI related tasks. Of all the...
jtpntx by Level 1
  • 67 Views
  • 1 replies
need to block exe file
Hi All, Need to block below exe file path on server. Can anyone help me how can i do this in Cisco secure endpoint console. c:\program files\uvnc bvba\UltraVNC\winvnc.exe
Vishal6 by Level 1
  • 63 Views
  • 3 replies
Network Architecture
Hello Everyone,I'm novice to networking. And below is the requirement I'm trying to figure out. Any leads would be greatly appreciated"You are working as an IT architect for a new startup business that grew faster than expected. they expanded to oper...
Ram253 by Level 1
  • 44 Views
  • 1 replies
WLC, SSO and OEAP
Hi I got a pair of 5520 in SSO mode version 8.10.190. If you want to run OEAP then you need to enable Enable NAT Address on the management interface. The problem is that the "Enable NAT Address" is greyed out: the question is: is it possible to enab...
Moudar by VIP
  • 79 Views
  • 2 replies
Tracking network speed
Hi thereI am assigned to check the issues with this attached network and have managed to remove some hups and redesign the network to what it is now. there were no vlans and it has been configured. the issue is that the internet speed is extremely sl...
