How to configure 2 WSA under one SMA with different configurations?
guibarati
Level 4
Level 4
Can anybody tell me if it's possible to have two WSA appliances managed by the same SMA but have different configs for each of the WSA? Different Identity profiles, access policies, etc.
2 Accepted Solutions
Atazazuddin Shaikh
Thanks for reaching out, Currently SMA  supports only 1 config master per WSA version.
Zack
6 Replies 6
No, not on the same Configuration Master
Thanks.
Can I have two configuration masters for the same version?
Not on the same SMA.
Atazazuddin Shaikh
Zack
Is it possible to have only reporting going to SMA and have configuration done locally?
Yes! (it felt good to be able to tell you yes!)
When you add the WSA to the SMA, just don't check the box for Centralized Configuration:
