ASDM Not opening
Hi All,
I have a Cisco ASA 5510 running on 9.1(5) image on it with ASDM 7.5(1). I am trying to open ASDM but it is not working. Java plugin is downloading and cached software is loading but after that it is not opening full ASDM console. Need your support in resolving this issue.
Thanks in advance,
Krishna
Ganesh Hariharan
Hi All,
Thanks in advance,
Krishna
Hi Krishna,
I hope you are using Java 7 Update 45 and openJava console (Windows - Control Panel Java - Select Security Tab Select Manage Certificates. Select Certificate Type and choose Secure Site) on a known working ASDM installed computer.
Export the "Trusted Site" cert and import it on the computer with ASDM issue.
Hope it Helps..
-GI
Rate if it helps..
