WCCP Slow Performance
johan.lagrand
I'm doing a POC of WAAS devices with one Accelerator in inline mode and the other in WCCP.
The WAVE in WCCP is configured as follow
interface GigabitEthernet 0/1
 ip address 1.1.1.2 255.255.255.252
 exit
wccp router-list 7 1.1.1.1
wccp tcp-promiscuous service-pair 61 62
 router-list-num 7
 assignment-method hash hash-source-ip
 redirect-method gre
 egress-method wccp-gre
 enable
 exit
The routeur as WCCP server on the Datacenter site has the following configuration
ip cef
ip wccp 61
ip wccp 62
interface GigabitEthernet0/0/0
 description WCCP DEVICE
 ip address 1.1.1.1 255.255.255.252
 ip wccp redirect exclude in
 negotiation auto
 description WAN
 ip address <WAN-IP>
 ip wccp 61 redirect in
 load-interval 30
 duplex auto
 speed auto
interface GigabitEthernet0/1
 description LAN
 ip address <LAN-IP>
 ip wccp 62 redirect in
 duplex auto
 speed auto
With that basic configuration we had slow performance, as there are no waas devices.
All interfaces are in full duplex mode (switch, router, WAAS device).
We can see that all trafic is match by the TFO,DRE,LZ policy in the show statistics connection.
The WCCP information on the router shows that the communication between the WAAS and the router is OK.
HQ-RTR#show ip wccp
Global WCCP information:
    Router information:
        Router Identifier:                   X.X.X.X
        Protocol Version:                    2.0
    Service Identifier: 61
        Number of Service Group Clients:     1
        Number of Service Group Routers:     1
        Total Packets s/w Redirected:        33552
          Process:                           0
          CEF:                               33552
        Service mode:                        Open
        Service Access-list:                 -none-
        Total Packets Dropped Closed:        0
        Redirect Access-list:                -none-
        Total Packets Denied Redirect:       0
        Total Packets Unassigned:            0
        Group Access-list:                   -none-
        Total Messages Denied to Group:      0
        Total Authentication failures:       0
        Total GRE Bypassed Packets Received: 30551
    Service Identifier: 62
        Total Packets s/w Redirected:        71378
          Process:                           0
          CEF:                               71378
        Service mode:                        Open
        Total GRE Bypassed Packets Received: 44498
I've done the test with both WAAS device in inline mode and we notice that the traffic is well accelerated and the compression is performed.
So It means that the policy configuration is good but the problem is in the WCCP configuration, either on the router, either on the WAAS device.
Any ideas ?
Johan
finn.poulsen
Level 3
Level 3
Hi Johan,
What model of router and what IOS version are you running ?
What is the CPU utilization of the router with WCCP enabled.
BTW: You don't need the "ip wccp redirect exclude in" when only doing "redirect in" on the LAN and WAN interface. This command is only required when "redirect out" is needed. Not that it should help on the performance.
Best Regards
Finn
Hi Finn,
Thanks for the reply ;)
The CPU is not impacted by the WCCP configuration, less than 5%
Here is the show version
ROUTEUR-SIEGE#show ver
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.1(1)T1, RELEASE SOFTWARE (fc2)
ROM: System Bootstrap, Version 15.0(1r)M9, RELEASE SOFTWARE (fc1)
HQ-RTR uptime is 3 hours, 16 minutes
System image file is "flash:c2900-universalk9-mz.SPA.151-1.T1.bin"
Last reload type: Normal Reload
Cisco CISCO2901/K9 (revision 1.0) with 1007616K/40960K bytes of memory.
Processor board ID FCZ1504C7C5
2 FastEthernet interfaces
3 Gigabit Ethernet interfaces
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
254464K bytes of ATA System CompactFlash 0 (Read/Write)
I will remove the redirect exclude and keep you inform,
