10-09-2015 01:24 PM - edited 03-08-2019 02:09 AM
I am trying to connect a new ASR, the only connection other than the one POS interface out to the internet, is to a 3750 so I can manage it outside of a serial connection. Here is what I have... I am unable to ping from one switch to the other. 12.175.12.28 to 12.175.12.26
3750
interface Vlan203
ip address 12.175.12.1 255.255.255.0
no ip unreachables
end
interface GigabitEthernet1/0/1
description ATT MIS ASR RTR
switchport access vlan 203
switchport mode access
speed 1000
duplex full
no cdp enable
end
also tried
switchport mode trunk
speed 1000
duplex full
no cdp enable
end
ASR1k
interface GigabitEthernet0/0/1
description To MDDDMZS01-NR03 Gi1/0/1
no ip address
speed 1000
no negotiation auto
end
interface GigabitEthernet0/0/1.203
encapsulation dot1Q 203
ip address 12.175.12.28 255.255.255.0
end
John
Solved! Go to Solution.
10-09-2015 04:59 PM
Can you try connecting them using a layer-3 link?
on the 3750
interface g1/0/1
no switchport
no sh
ASR
no sh
are the physical interfaces up?
10-09-2015 04:59 PM
on the 3750
interface g1/0/1
no switchport
no sh
ASR
no sh
10-13-2015 06:49 AM
Reza,
Thanks for the response. I am unable to address the interface on the 3750 because I have the vlan interface configured there.
interface Vlan203
no ip unreachables
end
VLAN 203 12.175.12.0 / 24 so when I try and add that address I get an overlap error.
% 12.175.12.164 overlaps with Vlan203
To make this a L3 link do I need a separate L3 network to route through? Say just a /30 network?
thank you,
John
10-09-2015 08:19 PM
Try this commands
conf t >> IP routing >>> on ASR1k . It is set by default. Just in case.
show vlan on both switch and ASR>> to see if vlan 203 has been created
show interface GigabitEthernet0/0/1 and other involved interfaces on both >> to check the status of interfaces
10-09-2015 09:25 PM
I am trying to connect a new ASR, the only connection other than the one POS interface out to the internet, is to a 3750 so I can manage it outside of a serial connection. Here is what I have... I am unable to ping from one switch to the other. 12.175.12.28 to 12.175.12.26 3750 interface Vlan203 ip address 12.175.12.1 255.255.255.0 no ip unreachables end interface GigabitEthernet1/0/1 description ATT MIS ASR RTR switchport access vlan 203 switchport mode access speed 1000 duplex full no cdp enable end also tried interface GigabitEthernet1/0/1 description ATT MIS ASR RTR switchport trunk encapsulation dot1q switchport mode trunk speed 1000 duplex full no cdp enable end ASR1k interface GigabitEthernet0/0/1 description To MDDDMZS01-NR03 Gi1/0/1 no ip address speed 1000 no negotiation auto end interface GigabitEthernet0/0/1.203 encapsulation dot1Q 203 ip address 12.175.12.28 255.255.255.0 end Thanks, John
Hi John,
First check the physical connection is up between 3750 and ASR. Then check the interface is not part of any vrf in ASR.
Then try configuring the interface with Layer 3 method for simple troubleshooting.
Hope it Helps..
-GI
