ā10-10-2015 07:31 AM - edited ā03-19-2019 10:12 AM
Hello-
I need to configure a SIP device which will indicate to users that there is a voice mail waiting by blinking. It will be installed on the ceiling for clear visibility. How should I configure this device? Do I have to consider this device as another SIP phone and configure it in CCM first and then in Unity?
This light is part of users who are configured in UCCX /Finesse. Can I configure something on CCG in UCCX?
Solved! Go to Solution.
ā10-12-2015 03:20 AM
you can register it at Sip third party endpoint on CUCM.
Add the assigned dn as message waiting indicator extension on User's voicemail.
Carlo
ā10-11-2015 04:41 AM
Hi.
No you have nothing to do within call control group .
For MWI you have to check which feature is supported on your device.
You can post the model and vendor and I can try to find if it can fit with that functionality.
Many third party sip devices support mwi with unity connection
Let me know
Carlo
ā10-11-2015 08:17 AM
It's a ALGO 8128R strobe light.
Carlo
ā10-12-2015 01:58 PM
Thanks Carlo....
my problem is I have already have 9 alter ext. configured in Unity and I can't add more (limitation for Unity). The reason I have 9 configured there is-we want to have all 9 staff members MWI turn ON when there is a message waiting for a general mail box. Do you think there is a different way of doing this? Like-creating VM profile and assign it to all 9 members!!!
ā10-13-2015 08:01 PM
Thanks Carlo....I got it working
