10-12-2015 04:01 AM - edited 03-08-2019 02:10 AM
Hi guys ,
im need some help here, i trying to connect two switches to gather with 2 up links cable , first switch L3 ( 3750 ) , i will connect this L3 switch to other Cisco switch (3850) .
i need how to configure ports on both .
Many thanks
Solved! Go to Solution.
10-13-2015 02:16 AM
Can you post the config from both switch ports, there should be 4 ports, 2 on each switch?
"yes , but not redundancy , i want use two ports as one link , i mean i want Cisco see the 2 ports as one port to get 2 G instead 1 G. "
You will get redundancy by default, if one link in the portchannel were to fail then the other would carry on passing traffic.
FYI, you don't get 2Gb of bandwidth per host.
You do get 2Gb of bandwidth total between the switches but each host will only be able to use 1Gb maximum.
10-12-2015 04:13 AM
I suspect you want to configure a Portchannel and use two wires for redundancy. Is this true?
10-12-2015 04:29 AM
is this right ?
and im sorry for bad language , im not perfect in English .
10-12-2015 04:48 AM
Configuration is pretty straightforward on both SWs:
interface Port-channel_you pick the ID
switchport trunk allowed vlan all
switchport mode trunk
interface one
channel-group 1 mode active
interface two
But I suggest you to prior read some articles about LACP and Cisco port channel as you might damage your current network configuration.
10-12-2015 05:34 AM
thanks ,
i get this error message :
Command rejected: An interface whose trunk encapsulation is "Auto" can not be configured to "trunk" mode.
i try this steps before but the same error.
10-12-2015 05:42 AM
Just add switchport trunk encapsulation 802.1q before.
10-13-2015 01:45 AM
Unfortunately , i do the below steps , but still no any connection between two switches . when i type : show cdp nei , no any link show !!! what is this mean ?
10-13-2015 02:16 AM
10-13-2015 03:32 AM
Yes , the below is config for L3 switch (3750) for :
interface Port-channel11
interface GigabitEthernet1/0/21
channel-group 11 mode active
interface GigabitEthernet1/0/22
if you need other switch config, feel free to tell me that.
10-13-2015 04:04 AM
Presumably the other switch is configured the same?
Can you post the results of the following:
#show int trunk
#show etherchannel summary
10-13-2015 04:34 AM
Yes, other switch (3850) the same
Wesam_L3#sho int trunk
Port Mode Encapsulation Status Native vlan
Po1 on 802.1q trunking 1
Po2 on 802.1q trunking 1
Po3 on 802.1q trunking 1
Po4 on 802.1q trunking 1
Po6 on 802.1q trunking 1
Port Vlans allowed on trunk
Po1 1-4094
Po2 1-4094
Po3 1-4094
Po4 1-4094
Po6 1-4094
Port Vlans allowed and active in management domain
Po1 1,10,20,30,40,50,60,70,80,90,100,200
Po2 1,10,20,30,40,50,60,70,80,90,100,200
Po3 1,10,20,30,40,50,60,70,80,90,100,200
Po4 1,10,20,30,40,50,60,70,80,90,100,200
Po6 1,10,20,30,40,50,60,70,80,90,100,200
Port Vlans in spanning tree forwarding state and not pruned
Wesam_L3#sho etherchannel summary
Flags: D - down P - in port-channel
I - stand-alone s - suspended
H - Hot-standby (LACP only)
R - Layer3 S - Layer2
U - in use f - failed to allocate aggregator
u - unsuitable for bundling
w - waiting to be aggregated
d - default port
Number of channel-groups in use: 10
Number of aggregators: 10
Group Port-channel Protocol Ports
1 Po1(SU) LACP Gi1/0/1(P) Gi1/0/2(P) Gi1/0/3(P)
Gi1/0/4(P)
2 Po2(SU) LACP Gi1/0/5(P) Gi1/0/6(P) Gi1/0/7(P)
Gi1/0/8(P)
3 Po3(SU) LACP Gi1/0/9(P) Gi1/0/10(P) Gi1/0/11(P)
Gi1/0/12(P)
4 Po4(SU) LACP Gi1/0/15(P) Gi1/0/16(P)
5 Po5(SD) -
6 Po6(SU) LACP Gi1/0/13(P) Gi1/0/14(P)
8 Po8(SD) -
9 Po9(SD) -
10 Po10(SD) -
11 Po11(SD) LACP Gi1/0/21(D) Gi1/0/22(D)
10-14-2015 01:06 AM
Please help you.
Any update
10-25-2015 12:25 AM
am still waiting
10-28-2015 07:28 AM
From the last status message, it indicates port-channel 11 is (D) or down. Can you shut down interface po11 on one of them and re-enable, and report what error messages there may be in the log, as to why the LACP wasn't enabled?
Also, it is odd that you don't get a CDP neighbor on the ports - it's possible you don't have CDP enabled; or there is a physical cabling issue (or SFP issue). What do you get on gi 1/0/21 and 22 when you so "sh int status gi 1/0/21"?
10-28-2015 10:57 PM
Firstly the the current status unplug cable because avoid and loop may be accured, cause am in live inviroment , the the CDP is enabled but , the last status the CDP neighbor discover 2 cables , but there is loop or any thing because high ping and disconnection between switches ,
Wesam_L3#sho INTERfaces G1/0/21
GigabitEthernet1/0/21 is down, line protocol is down (monitoring)
Hardware is Gigabit Ethernet, address is f025.72b7.a415 (bia f025.72b7.a415)
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Keepalive set (10 sec)
Auto-duplex, Auto-speed, media type is 10/100/1000BaseTX
input flow-control is off, output flow-control is unsupported
Last input 3w0d, output 1w2d, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
1 packets input, 64 bytes, 0 no buffer
Received 1 broadcasts (0 multicasts)
0 watchdog, 1 multicast, 0 pause input
349149443 packets output, 44258136358 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
Wesam_L3#
port is down now to avoid any loop , this configuration is true ?
if you need any accesss to this switch let me know, i need solve this problem.
