Hello Everyone
I have 2 WLCs in Site A,1 WLC in Site B and 2 SSIDs
Site A:
Primary WLC: Most of APs are registered in this WLC (Version 7.0.250.0)
Anchored WLC: This is only for Guest Wireless (Version 7.4.121.0)
Site B:
Backup WLC: some APs are registered in this WLC (Version 7.0.250.0). In my opinion, none AP should be registered here if the primary WLC is active
And the company bought a new WLC (Version 7.4.121.0), only the APs in the headquater building will be registered in this WLC, the secondary WLC will be the WLC in site A, and the tertiary will be the WLC in Site B
My plan is set up the WLCs (primary, secondary and tertiary) in each headquater AP manually, and i will reconfigure the APs that are registered in the backup WLC to change them to the primary WLC.
Do you know any other way to do this automatically or any advice in this design?
