ACS 5.2 Backup Restore on ACS 5.7
Antonio Knox
Level 7
Level 7
All,
I've been combing through documentation for a direct answer to this, but can't find one.
I have a 5.2 ACS appliance that I need to replace it with another appliance running ACS 5.7.  From what I've found, you would need to be running 5.5 to upgrade to 5.7, and I'm assuming that's because of the DB conversion requirements.  With this in mind I'm thinking that the DB in 5.2 is incompatible with 5.7, which leads to my main question...
If I do not have the luxury of upgrading to 5.5 is there another way to get my backup restored to an ACS 5.7 system?
Ivan Gonzalez
Hi Antonio,
You are right, 5.2 backup can not be restored on ACS 5.7 version and there is not an option to do it directly. ACS 5.2 backup can only be restored on 5.4 version.
What you might be able to do is the following:
-Install ACS 5.4 in your ACS currently running 5.7
-Restore you ACS 5.2 backup into the ACS 5.4
-Upgrade the ACS running 5.4 to 5.6 and then to 5.7
Note: Please mark it as answered if applicable.
6 Replies 6
Ivan Gonzalez
Hi Antonio,
ivangonz,
Thank you for your reply.  I'll try this and see how it goes.
Antonio, you are very welcome.
Hi Antonio,
I have similar challenge here too....
How did you restore the backup from the old cisco acs to new cisco acs?
I have downgraded my cisco acs to 5.4, but i am having issue on how to restore the backup to it.
Any document will be appreciated.
Thanks.
Hi Olagokemjb,
We have cli commands restore the backups from CLI ,Please use the below URL .
http://www.cisco.com/c/en/us/td/docs/net_mgmt/cisco_secure_access_control_system/5-4/command/reference/cli/cli_app_a.html#72936
Could you please let us know ,if any help required for it.
VenkataKrishna
Please rate helpful posts and mark correct answers.
This solution worked out great!  Thanks again.
