10-18-2015 04:38 AM
Hi All
We move a lot of equipements from managed to unmanaged state on the collector appliance. Upload is done and marked as successful om the portal. Unfortunately we still see those devices on the STNC smart services portal.
Why are they still visible (since they are not anymore inside the upload) and how could we force the portal to only use the last "installed base" out of our CSCP upload?
kind regards,
Michel Renfer
10-20-2015 03:46 AM
Hi Michel,
The query is clarified on the discussion thread:
https://supportforums.cisco.com/discussion/12629921/sntc-inventory-management#comment-10851341
Sherly
11-23-2015 06:03 PM
Hi Michel,
With the SNTC 3.3 release, we have introduced the ability for a user to indicate if they want their reports to be based on devices from the "latest" uploads from their collector(s) or based on all devices from prior uploads.
Based on your question, I believe you'll want to select the "Latest" setting.
Please see Applications Settings/Report Preference to set your desired option.
Bobby
