Warning message
switch 2960s configuration for dark fiber test
Answered Question
Oct 19th, 2015
hi guys
im new in networking. we have a dark fiber testing from Side A > dark fiber > Side B . to test the fiber link , im using a switch 2960 and configure a vlan - vlan 31, and i assign 1 of the port to switchport access vlan 31. im not sure whether the switch need to configure a default gateway which is the other switch tat side B. im not able to ping to my pc either [port 2/0/1]. the fiber link which connected to the switch is port 2/0/49]
can you help me to check whether this configuration is correct ?  below is the running config. tx so much for the help.
SRO-SWITCH-TEST#sh run
Building configuration...
Current configuration : 2679 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname SRO-SWITCH-TEST
boot-start-marker
boot-end-marker
enable password 7 110A1016141D5F01072728
username admin privilege 15 password 7 00071A150754
no aaa new-model
clock timezone MYS 8
switch 2 provision ws-c2960s-48ts-l
spanning-tree mode pvst
vlan internal allocation policy ascending
ip ssh version 2
interface FastEthernet0
 no ip address
interface GigabitEthernet2/0/1
 switchport mode access
 no mdix auto
 spanning-tree portfast
interface GigabitEthernet2/0/2
interface GigabitEthernet2/0/3
interface GigabitEthernet2/0/4
interface GigabitEthernet2/0/5
interface GigabitEthernet2/0/6
interface GigabitEthernet2/0/7
interface GigabitEthernet2/0/8
interface GigabitEthernet2/0/9
interface GigabitEthernet2/0/10
interface GigabitEthernet2/0/11
interface GigabitEthernet2/0/12
interface GigabitEthernet2/0/13
interface GigabitEthernet2/0/14
interface GigabitEthernet2/0/15
interface GigabitEthernet2/0/16
interface GigabitEthernet2/0/17
interface GigabitEthernet2/0/18
interface GigabitEthernet2/0/19
interface GigabitEthernet2/0/20
interface GigabitEthernet2/0/21
interface GigabitEthernet2/0/22
interface GigabitEthernet2/0/23
interface GigabitEthernet2/0/24
interface GigabitEthernet2/0/25
interface GigabitEthernet2/0/26
interface GigabitEthernet2/0/27
interface GigabitEthernet2/0/28
interface GigabitEthernet2/0/29
interface GigabitEthernet2/0/30
interface GigabitEthernet2/0/31
interface GigabitEthernet2/0/32
interface GigabitEthernet2/0/33
interface GigabitEthernet2/0/34
interface GigabitEthernet2/0/35
interface GigabitEthernet2/0/36
interface GigabitEthernet2/0/37
interface GigabitEthernet2/0/38
interface GigabitEthernet2/0/39
interface GigabitEthernet2/0/40
interface GigabitEthernet2/0/41
interface GigabitEthernet2/0/42
interface GigabitEthernet2/0/43
interface GigabitEthernet2/0/44
interface GigabitEthernet2/0/45
interface GigabitEthernet2/0/46
interface GigabitEthernet2/0/47
interface GigabitEthernet2/0/48
interface GigabitEthernet2/0/49
 speed nonegotiate
interface GigabitEthernet2/0/50
interface GigabitEthernet2/0/51
interface GigabitEthernet2/0/52
interface Vlan1
 no ip address
 shutdown
interface Vlan31
 description SRORO OFFICE
 ip address 192.168.31.250 255.255.255.0
ip http server
ip http secure-server
line con 0
line vty 5 15
end
SRO-SWITCH-TEST#
Correct Answer by chhayheng about 1 year 10 months ago
hi haslinifairos,
Case 1: If the different subnet you need to add route with each other.
Case 2: If the same subnet you need to turn off your computer firewall and make sure that both sides are the same range.
--Chhayheng--
Correct Answer by Mark Malone about 1 year 10 months ago
Hey config looks ok just missing default gateway locally pointing to other switch as you said
pc needs to be set with gateway of 192.168.31.250 vlan 31 and have a static ip in same range and same subnet
make sure your vlan 31 is up/up
Overall Rating: 5 (2 ratings)
Correct Answer
Mark Malone Tue, 10/20/2015 - 02:59
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 LAN
Correct Answer
chhayheng Wed, 10/21/2015 - 08:31
hi haslinifairos,
--Chhayheng--
haslinifairos Wed, 10/21/2015 - 13:36
Tq Chhayheng , Malone
i have configured the same subnet for both switches in Side A & Side B , and not configure any default gateway, its working at pingable each other. while at the same time, i turn off the PC firewall , its working. :)
