Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
"I have voice signaling with dscp 34 , If we look at this tables , can you guys tell me is it prioritized ?"
Insufficient (posted) information to tell. (Older Cisco switches have QoS disabled by default, so don't even know if these tables are "active".)
"I don't see 34 in the Cos-dscp map so I guess its not , correct ?"
No, you cannot tell that either. All the cos-dscp table tells you, a CoS value wouldn't translate to DSCP 34.
