10-20-2015 07:32 PM - edited 03-08-2019 02:18 AM
I have an EIGRP issue hopefully someone can help me with. I have a 2821 router with three static routes to VLANs that exist on a switch it's connected to. I want to share these routes with the rest of my network. I thought a "redistribute static" command would do this, but it does not.
I can run a "show ip eigrp topology <network> <network mask>" on the router and other equipment in the eigrp network and the network information comes up, but I can't ping any of the VLANs from anything but the router. My EIGRP statement also includes "no auto-summary" but that does not help either. Below is the results of the "show ip eigrp topology" command.
router#sh ip eigrp XXX top 10.X.47.0 255.255.255.0
IP-EIGRP (AS XXX): Topology entry for 10.X.47.0/24
State is Passive, Query origin flag is 1, 1 Successor(s), FD is 28160
Routing Descriptor Blocks:
10.X.0.15, from Rstatic, Send flag is 0x0
Composite metric is (28160/0), Route is External
Vector metric:
Minimum bandwidth is 100000 Kbit
Total delay is 100 microseconds
Reliability is 255/255
Load is 1/255
Minimum MTU is 1500
Hop count is 0
External data:
Originating router is 10.X.X.3 (this system)
AS number of route is 0
External protocol is Static, external metric is 0
Administrator tag is 0 (0x00000000)
Solved! Go to Solution.
10-22-2015 11:51 AM
You need a network entry on both devices for the IP subnet that they connect on.
So if that is the IP subnet that they have in common and how they connect yes you need entries on both.
Jon
10-20-2015 09:40 PM
Make sure those static routes are placed in 2821 routing table. Does your switch has default gateway or route to 2821 to return the packets?
"Show IP route"
10-21-2015 04:39 AM
Masoud, the switch's default gateway is the router and the static routes do show up when I run the "sh ip route" command.
I did notice when I run the "sh ip eigrp topology" command that the route shows up as 'external' not sure if this has any relevance.
10-21-2015 04:59 AM
can you check if there are no distribute list that can filter the routes going out of the 2821 or being recieved by other network devices?
i think a cleaned up config can help a lot
10-21-2015 05:27 AM
Adam
You seem to be saying the routes are there on other devices in the topology table.
Are they in the routing tables ?
If so your problem is not with EIGRP.
Jon
10-21-2015 05:38 AM
Sorry John. My answer is the same as yours. I saw your answer after I posted.
10-21-2015 06:06 AM
Hi Masoud
No problem, it happens to all of us and at least we were saying the same thing :-)
Jon
10-21-2015 05:28 AM
it is correct because redistribution marks routes as external. Did you check routing table of other devices. You might have received that route on other devices and had another problem to reach your switch.
10-21-2015 07:08 AM
can you post the topology of the router that isnt redistributing static, what other protocols have you go ie anycast .
10-22-2015 10:40 AM
Thanks for everybody's replies so far. After assessing the situation further, it looks like the switch the router is attached to (3750-X) should be able to do full EIGRP. I've added an EIGRP statement to the switch, matched the EIGRP numbers, and the switch and router can ping each other, yet they won't become neighbors.
I've run through the "neighbor check" section on the support document below and I'm at the "your problem is not a common problem" block.
http://www.cisco.com/c/en/us/support/docs/ip/enhanced-interior-gateway-routing-protocol-eigrp/21324-trouble-eigrp.html#nc
Any help is appreciated.
10-22-2015 11:11 AM
If the vlans are on the switch why are you trying to redistribute static.
Can you please explain exactly what you are trying to do and provide configs and then we may be able to help you.
Jon
10-22-2015 11:31 AM
Jon, I apologize for not clearing it up more. I didn't think my switch could do full EIGRP so I thought I could set those VLANs as static routes to the local router, then redistribute those to the rest of my network. Since that didn't work I did some more research and found out I could do full EIGRP on the switch.
Since I could, my plan was to advertise those subnet/VLANs through EIGRP on the switch to the rest of the network.
10-22-2015 11:36 AM
Okay, I understand now, thanks for clarifying.
That redistribute static plan should have worked although I understand you now want to run EIGRP between the devices which makes more sense.
The fact it isn't working may be part of the same issue.
How is the switch connected to the router ie. using a L3 P2P link or a vlan and an SVI on the switch ?
Either way have you included the a network statement for the actual IP subnet used to connect the devices under the EIGRP configuration on both of them ?
Otherwise could you post the relevant parts of the configurations.
Jon
10-22-2015 11:43 AM
They're connected by a VLAN and SVI on the switch.
Your second question, are you saying I need both the router and the switch advertising the same network over EIGRP? For example, say my network was 11.1.1.0/24. Would I need a line in the 'router eigrp <number>' section that says 'network 11.1.1.0 0.0.0.255'?
10-22-2015 11:51 AM
Jon
