10-20-2015 07:37 PM - edited 03-17-2019 04:38 AM
i config the dial-peer like this
dial-peer voice 1007 pots
translation-profile incoming CallBack
call-block translation-profile incoming call_block
call-block disconnect-cause incoming call-reject
incoming called-number 843791...
fax rate disable
direct-inward-dial
dial-peer voice 1008 pots
incoming called-number 843792...
fax rate disable
direct-inward-dial
dial-peer voice 1006 pots
translation-profile incoming E1-incoming
service csyw
incoming called-number 8437....
fax rate disable
direct-inward-dial
but when i dial a number 84379110,the call should match 1007 but it match 1006,why ????
.Oct 21 10:16:51.808: //-1/A039182898E2/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=
----- ccCallInfo IE subfields -----
cisco-ani=13311173269
cisco-anitype=2
cisco-aniplan=1
cisco-anipi=0
cisco-anisi=3
dest=84379110
cisco-desttype=4
cisco-destplan=1
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
cisco-redirectreason=-1 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
.Oct 21 10:16:51.808: //-1/A039182898E2/CCAPI/cc_api_call_setup_ind_common:
Interface=0x14FE6664, Call Info(
Calling Number=13311173269,(Calling Name=)(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
Called Number=84379110(TON=Subscriber, NPI=ISDN),
Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
Incoming Dial-peer=1006, Progress Indication=NULL(0), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
.Oct 21 10:16:51.808: //-1/A039182898E2/CCAPI/ccCheckClipClir:
In: Calling Number=13311173269(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
Out: Calling Number=13311173269(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
.Oct 21 10:16:51.808: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
.Oct 21 10:16:51.808: :cc_get_feature_vsa malloc success
.Oct 21 10:16:51.808: cc_get_feature_vsa count is 226
.Oct 21 10:16:51.808: :FEATURE_VSA attributes are: feature_name:0,feature_time:369343064,feature_id:936110
.Oct 21 10:16:51.808: //1460499/A039182898E2/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=13311173269(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
Called Number=84379110(TON=Subscriber, NPI=ISDN))
.Oct 21 10:16:51.808: //1460499/A039182898E2/CCAPI/cc_process_call_setup_ind:
Event=0x245DBE0
.Oct 21 10:16:51.808: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 84379110
.Oct 21 10:16:51.812: //1460499/A039182898E2/CCAPI/ccCallSetContext:
Context=0x133506C4
.Oct 21 10:16:51.812: //1460499/A039182898E2/CCAPI/cc_process_call_setup_ind:
>>>>CCAPI handed cid 1460499 with tag 1006 to app "_ManagedAppProcess_CSYW"
.Oct 21 10:16:52.008: //1460496/9FBDCD5298E1/CCAPI/ccCallSetupAck:
10-20-2015 07:48 PM
Hi.
This because dialpeer is more specific for dialed number
On DP 1007 you have
incoming called-number 843791... ( 3 dots)
while on DP 1006 you have
incoming called-number 84379...
which is the best option for dialed number
Try to eliminate a dot from DP 1007 and it should be the best option
Let me know
Carlo
10-20-2015 10:57 PM
a ....sorry ....i mistake
the right is 843791.. 2dot...
10-20-2015 10:01 PM
First of all, you having overlapping dial-peer which can cause this issue this is not at all recommended to configured in such way .either Set the preference or set inter-digit time out . also you apply the configuration as suggested carlo too.
br,
Nadeem
