10-21-2015 12:52 PM - edited 03-01-2019 12:25 PM
Unable to Log in Fabric Interconnect using Active directory domain ID. UCSM is integrated with Active directory and able to login UCSM using my Active directory ID but not able to log in CLI using same ID. help me on this
10-21-2015 01:35 PM
Senthil,
If you try logging in to the CLI with the below format do you get any different behavior?
"ucs-[domain name]\[username]" including the quotes.
Or could you try opening an ssh session with the following setup...
"domain\username"@ipaddress
10-21-2015 02:09 PM
I tried both way , still same issue, I am getting access denied error
10-22-2015 05:42 AM
Do you have 2 authentication domains
Have a look at
http://ucsguru.com/2012/06/26/cisco-ucs-active-directory-integration/
or
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/sw/sample_configurations/UCSM_1_4_LDAP_with_AD/b_Sample_Configuration_LDAP_with_AD.pdf
10-27-2015 06:17 AM
Can you please paste here how you are logging and the error you get...?
-Kenny
11-16-2015 06:11 AM
I have found that the domain login field is case-sensitive and has to match how your entered your domain name with the All>User Management>Authentication>Authentication Domains settings.
In my case, I have to use ucs-MyDomain.com\username to login via CLI.
You can find the correct value to enter from the lower left corner of the UCS Manager Window after you have logged in. It will show "Logged in as ucs-something..............." Match your CLI login using the same case shown and hopefully that will resolve it.
Ernie
