TMS Video Conference MAster API Commands
Brandon Rebbe
I have a scenario where we are using the Video conference master setting in TMS to try and define some settings in a room that are controlled by a third party controller.
So if one site is the master we setup profiles like back camera on back monitor on sharing specific content etc...
I have gone through the API document to find some answers but I cannot find what I am looking for.
When TMS books a call does any of that info get stored locally on the codec before the call starts?  So I could query the codec to find out if it was the master in the next cal..
I found that the conferencing object holds the info that I need, but I am not sure how to get to it.  I could go in and pars the data I need I would think.
My though process would be to get the call ID once it was first booked and updated to the meeting list on the codec, then go to the booking object for that call ID and parse the xml file.
I know this is a weird one but am Is my thinking correct that there is a booking object file for each call?
Sebastian Hughes
HI Brandon,
If I understand your question correctly you can run the command on a TC endpoint:
xcommand Bookings list
This will provide information about the meeting as well as the following line:
*r BookingsListResult Booking 1 Role: Master
If it is not Master it will say Slave
Hope this answers your question
Sebastian
Sebastian Hughes
HI Brandon,
Sebastian
I think this is what I am looking for.  I am going to test this today.
That command shows me what I need before the call.  Is there anything I can run during the call that shows that?  I can use xstatus call and xstatus conference to get info including the conference ID which I could then reference with the bookings to match it up.
But, is there anyway to query a call that has already started to find out who is the master or slave?
