Showing results forĀ
Search instead forĀ
Did you mean:Ā
Does the Catalyst Switch 2960-24TT-L support OpenFlow?
Patrick1965
Hi there,
I'm a fourth year networks student and as part of my FYP would like to find out if the 2960 switches support OpenFlow. Failing that is there an update or something similar that could be added.
The IOS version is 15.0(2)SE5. machine S/N: FOC135ZY5ZQ
I've gone through spec. and data sheets but can't find anything to indicate either way.
Any info. would be gratefully received.
Best regards,
Pat.
0 Replies 0
