10-29-2015 02:05 PM - edited 03-18-2019 05:09 AM
Does anyone know if there's a way to reset the menu password on a C90 v7.3.3?
I run through an IPDC and Market Central switch for classified/unclassified. Would a factory reset break any configuration related to those components?
I have SSH access, but can't seem to get the web interface.
Appreciate any help.
Mike
Solved! Go to Solution.
10-29-2015 04:58 PM
xCommand SystemUnit MenuPassword Set Password:"" clears the existing password.
Factory reset would most probably break those configs as this will reset settings to default values.
To maybe, give you a clue as to why you can't access web gui, ssh into the box go systemtools network netstat - if webserver is running you should see ports 80 and/or 443 in the list. Turn on/off using xConfiguration NetworkServices HTTP (and/or HTTPS) Mode: <Off, On>
/jens
Please rate replies and mark question(s) as "answered" if applicable.
10-29-2015 04:58 PM
/jens
11-02-2015 10:35 AM
Thank you Jens. That did the trick.
10-29-2015 05:02 PM
To reset the password that is used to access the on screen menu use the API command Jens provided using SSH.
Factory reset would clear all configuration of the codec, and resotre all settings to default including accounts and passwords.
Are you saying you can't browse to the web interface or you can't login, have you tried to login using the the admin account you used to log into SSH?
11-02-2015 10:31 AM
I've resolved this. Turns out the codec didn't like my version of IE. It would say something like "authentication sucessful", then "redirecting" and dump me right back to the login screen. Worked like a charm when I put Firefox on.
