10-30-2015 11:24 AM - edited 03-05-2019 06:59 AM
Please i have an ASA 5545 with 9.2 (3) OS, I need to NAT some traffic to some servers in my LAN.
I have two DMZs (Untrust and DMZ_MPLS) from which users will access to the servers (Inside zone).
I did NAT to the inside server (172.16.1.11 (inside)) via public IP (196.25.199.38 (Untrust)) on some ports (http and so on). But ASDM refused to do another NAT. i have an error the ipoverlad with another NAT.
This is what i want to do :
inside IP Public IP/MPLS I¨P services
172.16.1.11 196.25.199.38 http, https
172.16.1.12 196.25.199.38 FTP, TFTP
172.16.1.11 10.81.10.82 http, https
172.16.1.12 10.81.10.82 FTP, TFTP
Please can you help me ?
10-30-2015 01:16 PM
If you share your config it would be much easier.
11-02-2015 06:22 AM
Ok this is the config i Did:
object network Host_Serveur_web
nat (Inside,Untrust) static Host_ext_SAP_web
access-list WEB_access_IN extended permit object-group WEB_SERVICE any4 object Host_Serveur_web
access-group WEB_access_IN in interface Untrust
object-group service WEB_SERVICE
service-object tcp destination eq www
service-object tcp destination eq https
Host_Serveur_web = 172.16.1.11
Host_ext_SAP_web = 196.25.199.38
I cannot add another one !
11-02-2015 06:45 AM
What is the purpose of translation of one IP address to two different IP addresses?
Do you have two external links? If so, you need to implement policy nat.
11-02-2015 06:58 AM
Nasoud, yes i want that users from MPLS Link who dont have access to Internet can access application. And other users outside the MPLS network can access via Internet.
11-02-2015 07:46 AM
I do not have ASA right now to test the commands.
1- Try to set two seperate object for
196.25.199.38 and 10.81.10.82
2- Try to set two different object for destinations
1- all destination (Internet any except your servers)
2-your servers. (only some servers)
and configure two access-lists with the same source and different destination(objects you defined for the destinations)
Then apply each access-list to a seperate NAT
You are receiving error because you did specifiy any destination and ASA can not differentiate between two NATs.
11-02-2015 11:37 AM
Hi Massoud,
The issue with the object is the inside one. I ve tried with the same error.
11-02-2015 12:14 PM
You need to use two different object names per inside server ie. the same server IP but two different objects.
The reason you are having the issue is you are trying to use the same object name to NAT to two different IPs ie. the DMZ IP and the public IP on the same ports.
Jon
11-02-2015 03:10 PM
I tried to implement your configuration.
// int vlan1 is toward servers. There are two routes to 1.1.1.2 toward servers.
interface Vlan1
nameif inside
security-level 100
ip address 1.1.1.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 196.25.199.38 255.255.255.0
interface Vlan3
nameif DMZ_MPLS
security-level 0
ip address 10.81.10.82 255.255.255.0
route inside 172.16.1.11 255.255.255.255 1.1.1.2 1
route inside 172.16.1.12 255.255.255.255 1.1.1.2 1
// all traffic is permited from outside and DMZ_MPLS to inside. You can limit it.
access-list to-server-permission extended permit tcp any any
access-list to-server-permission extended permit icmp any any
access-group to-server-permission in interface outside
access-group to-server-permission in interface DMZ_MPLS
// I created two Objects for each server.
object network server1
host 172.16.1.11
object network server2
host 172.16.1.12
object network server3
host 172.16.1.11
object network server4
host 172.16.1.12
nat (inside,outside) static 196.25.199.38 service TCP http https
nat (inside,outside) static 196.25.199.38 service TCP FTP
nat (inside,DMZ_MPLS) static 10.81.10.82 TCP http https
nat (inside,DMZ_MPLS) static 10.81.10.82 TCP FTP
Are able to set to NAT commands under one network object?
Something like this.
host 172.16.1.11
11-03-2015 05:54 AM
Thanks i will try the config and let you know !
Cdly
11-02-2015 09:01 AM
Am not able to see documentation about policy NAT,
PS: am on version 9.2
11-02-2015 09:45 AM
Please check the links below for get some idea.
http://www.tech21century.com/policy-nat-on-cisco-asa-firewall/
http://www.astorinonetworks.com/2012/02/03/configuring-natpat-on-the-asa/
11-02-2015 09:57 AM
Only these commands are doing actual nat for you. Other commands are just access-list for allowing traffic.
you need to add access-list to specify you destination
nat (Inside,Untrust) static Host_ext_SAP_web access-list ( Host_ext_SAP_web to internet)
nat (Inside,Untrust) static Host_ext_SAP_web access-list(Host_ext_SAP_web to servers)
and then you need to allow traffic with another access-list
I suppose your two external links are both connected to untrust. Right?
11-02-2015 06:56 AM
Run this packet tracer and post the result:
packet-tracer input Untrust tcp 8.8.8.8 456 196.25.199.38 80
The reason why you can't add another one is because you are doing a static NAT statement, you need to perform port-forwarding to reuse the same public IP address.
Example:
object service tcp-eq-80
service tcp source eq 80
object service tcp-eq-443
service tcp source eq 443
nat (Inside,Untrust) source static Host_Serveur_web Host_ext_SAP_web service tcp-eq-80 tcp-eq-80
nat (Inside,Untrust) source static Host_Serveur_web Host_ext_SAP_web service tcp-eq-443 tcp-eq-443
