I am having trouble with my access points, once I've installed Cisco router RV325. Internet connections on access points are very slow and they break. It is hard to get access to internet, and if connected it takes a lot of time to open web page in browser on cell phone.
I used to have linksys router before and everything worked great, but now it works good only on PC that are connected via Ethernet cable.
Main router (192.168.10.10) is configured as DHCP server (range 192.168.10.100 -> 192.168.10.150), while DHCP is disabled on all access point (AP1 192.168.10.4; AP2 192.168.10.14; AP3 192.168.10.8). Access points are TP LINK (TL-WR841N / TL-WR841ND, TL-WR340G).
On router I have turned on Firewall is configured:
- Firewall: Enable
- SPI(Stateful Packet Inspection): Enable
- DoS (Denial of Service): Enable
- Block WAN Request: Enable
- Remote Management: Enable Port:
- Multicast Pass Through: Enable
- HTTPS: Enable
- SSL VPN: Enable
- SIP ALG: Enable
- UPnP: Enable
Features below are disabled in Firewall: - Java
- Cookies
- ActiveX
- Access to HTTP Proxy Servers
Cisco Router is connected to Switch TP LINK (TL-SL3452) where DHCP is disabled as well. Only on Cisco router DHCP is enabled.
As I have mentioned, everything worked before I just replaced main router with the Cisco RV325 model.
I was wondering if Firewall can block this, or does anyone have an idea what could be the problem?
