OTU2-XP configuration inquiry
Emyrsonn Rodil
I have an OTU2-XP set as Transponder carrying 10GE traffic in ports 1&2...
I need a LAN PHY to WAN PHY application which can only run in ports 1&2.
I plan to transfer the traffic in ports 1&2 to 3&4...
Will I need to delete all circuit provisioned in the OTU2-XP to modify its card configuration from "Transponder" to "10G Ethernet LAN Phy to WAN Phy"?
Thank you...
Emyrsonn Rodil
I was able to find a spare OTU2-XP ...
Now I need to configure it as 10GE LAN Phy to WAN Phy using ONS-XC-10G-S1=...
After provisioning the card configuration, what else do I need to do?
Do I need to create a circuit for this requirement, LAN Phy to WAN Phy?
