11-05-2015 08:22 AM - edited 07-05-2021 04:11 AM
Does anyone have an idea when FlexConnect mode will be supported for the 1850 access points?
11-05-2015 09:36 AM
What controller and version are you running?
The 1850 data sheet lists flexconnect as supported.
http://www.cisco.com/c/en/us/products/collateral/wireless/aironet-1850-series-access-points/datasheet-c78-734256.html
11-05-2015 10:20 AM
Agreed. It says it does. But what you (and I) missed is that little asterik next to the FlexConnect trademark...
5508 WLC running 8.1.111.0
The release notes for the version I'm running and version 8.1.122.0 say its not supported.
11-05-2015 10:22 AM
Ahh well look at that. Emphasis on the word little.
11-11-2015 08:41 AM
Also not available with 8.1.131.0
11-12-2015 01:21 AM
Refer the link : http://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn81mr1.html#pgfId-1301299
11-17-2015 07:16 AM
Does anyone know why it isn't supported and if there is a time table on when it will be?
11-18-2015 07:05 AM
No idea. You would have to get with yoru account team and hav ethem push the inquiry with the business unit. They would be able to check on development status.
Please rate useful posts and mark answers as correct if applicable.
06-22-2016 09:30 AM
dear,
upgrade it to 8.2, according to the release its now supported.
http://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn82mr1.html#pgfId-1437193
10-25-2016 11:18 AM
I have 8.2.100.0 and it is not supported here
as I've read in the release notes the first IOS that removes the comment is 8.2.110.0
12-02-2016 01:21 AM
Does anyone have a working 1830/1850 access point with flexconnect and 8.2.121.0?
12-02-2016 02:04 AM
Yep I do.
Can you be a little more explicit about what you need to know? What sort of setup in so far as controllers? Are you running a supported version of code?
12-02-2016 11:17 AM
Thanks for your fast reply. I'm currently running two 5520 controllers with version 8.2.121.0. In the past we used 1702 access points and now we want to switch to the latest models. Just wanted to verify if this version is supporting flexconnect with this kind of access points now.
12-02-2016 02:47 PM
Yes - it does. The config from your controller is the same as any other AP - select FlexConnect from the dropdown box in the GUI. Works just fine.
Note that the version of WLC software that you are running is deferred. To pick up lots of good bug fixes you might want to move to 8.2.130.0 . As these APs are still relatively new (new architecture and new OS on the APs) there are still lots of important functionality and stability fixes going into the MR's.
[Don't move to 8.3 yet, stay on 8.2]
12-03-2016 03:50 PM
OK I'll schedule an update for January. Thanks for all your help.
