11-05-2015 11:01 AM - edited 03-08-2019 02:35 AM
hi all,
In my nexus 7700 (have 2 in vpc active / standby) when I do "show ip arp " in the 7700 primary I only see 4 entries, if I do the same in the secondary, I see 46 entries.
This 2 devices hace the same configuracion and are connected to the same devices.
Why do I have this type of output?
thanks.
11-05-2015 01:34 PM
Can you provide a copy of your config and a show vpc br on both?
-AO
11-07-2015 05:31 AM
Hi all
I will send the configs of both vpc, and Domains. and Im shure I did not enable the ip arp sync.
Thanks.
11-08-2015 01:28 AM
Hi all,
This is the config for the vpc domain and it ths very standar.
configure terminal
vpc domain 10
My question is I have mode then 1 domain should I configure the ip arp syn on all of them?
thanks.
11-08-2015 04:32 AM
Hi all, This is the config for the vpc domain and it ths very standar.configure terminal vpc domain 10 !My question is I have mode then 1 domain should I configure the ip arp syn on all of them?thanks.
vPC domain would be 1 with having two switches. So you configure the belwo under domain 10.
N7k1switch#conf t
N7k1switch(config)#vpc domain 10
N7k1switch(config-vpc-domain)#ip arp synchronize
Hope it Helps..
-GI
Rate if it Helps
11-09-2015 07:07 AM
Hi all,
I addeds to the vpc domain I have the "ip arp synchronize" but still not seeing all the same macs in both devices.
thanks.
11-09-2015 11:54 PM
What is your show vPC output from both the switches.
-GI
11-10-2015 05:42 AM
Hello Ganesh,
This is the output.
Site 2
show vpc
Legend:
(*) - local vPC is down, forwarding via vPC peer-link
vPC domain id : 1
Peer status : peer adjacency formed ok
vPC keep-alive status : peer is alive
Configuration consistency status : success
Per-vlan consistency status : success
Type-2 consistency status : success
vPC role : secondary
Number of vPCs configured : 2
Peer Gateway : Disabled
Dual-active excluded VLANs : -
Graceful Consistency Check : Enabled
Auto-recovery status : Enabled (timeout = 240 seconds)
Site 2
show vpc
Legend:
vPC domain id : 1
vPC role : primary
Thanks.
11-11-2015 02:32 PM
Hello Ganesh,
Im still with the issue with the Ip apr syn not showing all the arps. in both devices.
thanks.
11-11-2015 10:01 PM
Hello Ganesh,Im still with the issue with the Ip apr syn not showing all the arps. in both devices.thanks.1124
Hello ,
Strange, I was doing some research on this peculiar issue.
And what i come to share is ip arp syncronize command is more of an updater than a protocol to synchronize the arp tables on both boxes.
The purpose of the feature was whenever the peer-link or SVI went down and came back up, the vPC peers will forward the ARP entries between the boxes so that to speed the ARP learning between the boxes after a re-convergence.
And what i found how the traffic works is It monitors to vpc peer-link up messages. If up message is seen, each of the switch will push its ARP entries to the other via CFSoE then both will update their ARP table if it is not already present.
and also checks for SVI up msg for updation of local arp entry.
And Normally ARP aging /deleting /refreshing etc are handled independently by each of the peer so what i feel you will never see the ARP tables in them synchronized.
But have you tried clear ip arp table on both the switches and chekced what is the output.
Hope it Helps..
-GI
Rate if it Helps..
11-05-2015 01:39 PM
Do you have arp synchronization enabled such as:
switch#conf t
switch(config)#vpc domain <domain-id>
Brandon
11-06-2015 10:05 PM
WIth vPV configiration between switches , A new feature was added to Cisco NX-OS to address table synchronization across vPC peers using the reliable transport mechanism of the Cisco Fabric Service over Ethernet (CFSoE) protocol.
The ip arp synchronize command must be enabled and support faster convergence of address tables between the vPC peers.
Configire the command under vPC configuration as per suggestion.
Hope it Helps.
-GI
Rate if it Helps
