11-10-2015 10:42 AM - edited 03-17-2019 04:51 AM
Trying to back up current configuration; prior to resetting the device and configuring for new setup.
The old IT guy for the company left on bad terms, and I was thrown into the mix.
I will be honest as I have no background in this type of system and any and all help is greatly appreicated!
If anyone could help walk me through the setup/configuration too, once I get the old configuration backed up, would be great!
11-10-2015 10:52 AM
Hi Richard,
are you able to reach 10.1.10.2 as reported from CNA tool?
Let me know
Carlo
11-10-2015 11:02 AM
The problem is the compny downsized and moved into a new office.
We have a SBS 2011 server, that handles and controls our network on a 192.168.0.x configuration.
At the prior office we had multiple static, and the phone system ran on its own network setup/configuration. And now we are trying to condense down, and have everything just run and configure through the server.
So I believe that is were a lot of the issue is stemming from.
11-10-2015 11:06 AM
Yes that should be the main issue.
Please verify that all connectivity is ensured between CME and backup server and let us know
Carlo
11-10-2015 11:08 AM
The UC 560 is conneced to a router, in which the server is attached to.
Running from port on router to PC/EXP (2) on the UC560.
I can launch the "Cisco Configuration Assistant" and connect/configure the UC560 from the server.
11-10-2015 11:11 AM
Great.. so,
which is the IP address of UC 500?
Cheers
Carlo
11-10-2015 11:16 AM
Router IP: 192.168.0.1
Server IP: 192.168.0.2
UC560 IP: 192.168.0.8
11-10-2015 11:26 AM
Can you please provide a screenshot of UC560 properties on CNA and , if you can , a show runn of UC560?
Carlo
