5585-X Cluster License
Goutam Biswas
I have two set of 5585-ssp20, and I would like to configure clustering betwee them.  But I couldn't see cluster license in the hardware delivery challan.  Is it require to order cluster license separately or with 5585-x cluster license is inbuild.
Goutam
Shivapramod M
Hi Goutam,
You need to have the license for the cluster.
Please refer the licensing section of the below link.
http://www.cisco.com/c/en/us/td/docs/security/asa/asa94/configuration/general/asa-general-cli/ha-cluster.html#pgfId-2552304
It is a free license. you need to get it and activate it in the device.
Hope this helps.
Shivapramod M
I cannot see that its mention license free.  Could you pls tell me where it is mentioned license is free.  I need to make sure during design otherwise its problem.
Goutam
Hi Gautam,
You need to buy a cluster license for ASA5585-ssp20 with security plus license (for 10gig I/O port support. Howver you do not required to buy the same license for all the slave units. They inherit the license from Master unit.
2 node cluster license is given bydefault with ASA5500-x with base license and same thing on ASA5512-x with Security plust license (same details  are available on the table mentioned) in the link above.
Hope it helps.
Akshay Rastogi
Remember to mark the answer as correct if it answers your queries and rate the helpful posts.
I can confirm it is a free license. The part number is L-ASA5585-CL-S20=.
