11-12-2015 07:23 AM - edited 03-17-2019 05:40 PM
I'm looking for an option to use the second or third line withe the Cisco Jabber Client Windows 11.1.1 Build 22531.
Is it possible?
thanks + regards
Michael
is is
11-12-2015 07:45 AM
No, right now all Jabber clients are single line.
11-12-2015 11:22 PM
That's not nice!
Is this feature "muliti line control" on the roadmap?
11-13-2015 07:14 AM
Roadmap items cannot be discussed at CSC as that's NDA information, you have two options to get that info:
A) If you're a partner, post this question in the partner community
B) If you're NOT a partner, either work with your partner to get this, or your SE/AM.
12-02-2015 08:37 AM
So based on this fact...what is another option which will accomplish this same scenario? CIPC?
12-02-2015 08:45 AM
Yes, currently if you want multi-line, the only option is CIPC.
12-02-2015 08:47 AM
Thanks for the quick feedback. This was my assumption, but I definitely wanted to confirm.
