11-13-2015 10:54 AM - edited 03-05-2019 02:44 AM
Hello everyone,
I have a 2821 router with 2 x VWIC2-1MFT-T1/E1 cards connecting ppp links in a bundle, we are replacing it with a 2951 but also adding a new ppp link, nevertheless we would like to reuse the existing VWIC2 cards and just procuring a new VWIC3-1MFT-T1/E1 card for adding this additional link in the same bundle, my question here: would it be possible to have a multilink working with vwic2 and vwic3 cards?
Thanks for your help.
Solved! Go to Solution.
11-15-2015 08:41 PM
I just checked one of my routers. I have ppp multilink on two different modules. wic-1dsu-t1-v2 and VWIC2-1MFT-T1/E1. So it should work in your case too.
multilink work properly.
Hope it helps,
Masoud
11-13-2015 08:18 PM
I think you would have no problem because E1/T1 cards provides layer one connectivity while ppp multilink is L2.
Masoud
11-15-2015 08:41 PM
Hope it helps,
Masoud
11-16-2015 09:38 AM
Thanks so much Masoud!
11-16-2015 09:40 AM
You are most welcome.
Masoud
