6.2.1 command line interface
Reginald Hill
I have a variable event that monitors a variable. When the variable changes, it triggers a job to run a report using the variable as the business unit. This process works. We enter a BU and the job triggers, running a BO report. I have another variable that is an array of our business units. I have a script that uses the command line interface and cycles through that array and then enters the BU number into the variable field to trigger the report. In 5.3.1 the script runs well with no issues. In 6.2.1 the script runs but it triggers the report job twice for each business unit. Do you have any ideas? Your feed back is greatly appreciated..
RHT
Derrick Au
Level 4
Level 4
Hi Reginald,
Can you please check in the Variable Event, and what does the Trigger History show?
Please verify.
BR,
Derrick Au
