CISCO 1941 Router (IPsec Issue)-MTU Value-1460
Natarajan Muthu
Hi ,
We are unable to access Core Application over the IPsec.If we removed the Ipsec from the interface.We can able to access the same.
Service Provider MTU Valu is -1460
Can anyone provide solution on this case.
trfinkenstadt
Natarajan,
can you try:
crypto ipsec df-bit clear
on your config.  you may have non-fragmentable packets getting dropped.  is your setup standard ipsec or gre/ipsec?
Hi ,
Said command already tried
Branch End Config
crypto isakmp policy 10
encr aes
authentication pre-share
group 2
crypto isakmp key XXXXXX address X.X.X.X
crypto isakmp keepalive 10 5 periodic
crypto ipsec security-association lifetime seconds 2000
crypto ipsec transform-set XXXXX esp-aes esp-sha-hmac
mode tunnel
crypto map cmap local-address Loopback0
crypto map cmap 10 ipsec-isakmp
description XXXXXX
set peer X.X.X.X
set transform-set XXXXX
match address 134
