11-18-2015 02:08 PM - edited 03-17-2019 04:56 AM
I have a 4331 router with PVDM4-128. I will be using this router for CME. I also have a NIM module with 1 port T1/E1. I will be terminating E1 PRI circuit in this card.
After reading this link
, I have the impression that I also need to have the PVDM installed in the NIM module in order to configure this port for voice circuit termination. Can somebody confirm whether the PVDM in the card is the must?
Thanks, Khanal
11-18-2015 02:35 PM
Hi Khanal,
You should be fine using the the PVDM4-128 installed on the motherboard (not NIM module) as shown in a clip from the config guide you linked;
"The Cisco PVDM4 is installed on a slot on the motherboard or on a Cisco Fourth-Generation T1/E1 Voice and WAN Network Interface Module."
Cheers!
Rob
11-18-2015 03:00 PM
Thank you so much Rob. It is very helpful.
Thanks, Badri
11-19-2015 06:42 AM
I ran into the following error while configuring the port. Does it mean I must have the PVDM in the card rather than in the board?
ISR4331RTR(config-controller)#pri-group timeslots 1-31
E1 0/1/0: No voice port or DSP resource for voice feature
E1 0/1/0: For MFT T1E1 modules, pri-group has to have DSP (PVDM4) modules installed.
E1 0/1/0: Please check if DSP module is plugged in before configuring pri-group!
E1 0/1/0: This pri-group configuration is REJECTED!
%No configuration will be applied
Thanks, Khanal
11-19-2015 07:44 AM
It seems that u have plugged PVDM4 card on motherboard.You need to plug on to NIM daughter card for E1/T1 connectivity.
can u share show inventory or show diag from router?
link says
The motherboard PVDMs are supported on all Cisco 4000 Series ISRs. They can be plugged directly into the single slot on the router motherboard or into the network interface module (NIM) that supports T1/E1 ports. A PVDM4 module plugged into the motherboard delivers IP-based voice services such as conferencing, media optimization, and transcoding only.
A PVDM4 module plugged into the T1/E1 NIM would be used for voice T1/E1 connectivity. Any excess channels can be reused toward other IP-based services supported on the motherboard slot. Enhanced DSP architecture accommodates a new packet-processing engine optimized for rich-media voice applications, while concurrently supporting the TDM-IP voice framework.
http://www.cisco.com/c/en/us/products/collateral/routers/4000-series-integrated-services-routers-isr/data_sheet_c78-728307.html
regds,
aman
11-19-2015 08:03 AM
Thank you Aman for responding. I will need the PVDM in the motherboard as well as I will need it for transcoding and conferencing. You and Rob made it clear to me now that I will need the PVDM in the NIM module so I will go ahead and order one.
Thank you.
Khanal
11-19-2015 07:42 AM
Hi Khanal,
I'm sorry for the bad info from my end, you are 100% correct.
When you try to configure voice PRI on ISR G4, this error appears:
T1 0/1/0: No DSP resources to configure voice feature
There is only one PVDM slot on the motherboard. The Time Division Multiplexing (TDM) cards can not use the motherboard PVDMs. Dependent upon the number of channels required, the appropriate DSP module is installed on the NIM. For IP services such as to transcode and conference, the PVDM4 DSP module can be installed on the motherboard of the ISR 4000 Series platform.
If the show inventory output shows this information, it signifies that the PVDM card is installed on the motherboard.
NAME: "PVDM subslot 0/4", DESCR: "PVDM4-32 Voice DSP Module"
PID: PVDM4-32 , VID: V02, SN: FOC18334AVD
Once the PVDM card is placed on the NIM, the show inventory command indicates:
NAME: "subslot 0/1 db module 0", DESCR: "PVDM4-128 Voice DSP Module"
PID: PVDM4-128 , VID: V01, SN: FOC17176BLL
11-19-2015 07:54 AM
Hi Aman,
Looks like we were posting up @the same time my friend! +5 for your great tips as always. Hope all is well with you :)
Cheers!
Rob
11-19-2015 09:05 AM
All is well.
[+5] to you for sharing more info.
regds,
aman
09-28-2016 01:49 PM
What happens if I move the PVDM4-128 from motherboard to T1/E1 NIM module?
Would I still be able to use for transcoder, etc? I just want to make sure as long as I'm going to use T1/E1 I must add a new PVDM on NIM module.
Thank you!
01-06-2017 09:26 AM
Hello All!
I am running into the same predicament, I was reading through this blog and unfortunately still a bit unclear. I was wondering if someone can help me out and clear things up for me.
As Gustavo was asking, will (2) PVDM modules be needed in order to have both a T1/E1 and for Trancoding/Conferencing?
We previously moved the PVDM4-128 from the motherboard to NIM, because i was unable to configure the T1 was receiving
Would I still be able to use that same PVDM install on the NIM for Transcoder/Conferening etc? I'm trying to figure out if we will need to purchase another PVDM module to install on the motherboard? In order to perform Transcoding/Conference.
Thanks in advance!
-Diana
01-06-2017 09:37 AM
Hi Diana,
NIM card needs PVDM4 to terminate TDM circuit, however any unused channels can be used for transcoding and conference.
Motherboard PVDM and extended service module PVDM can also be used for transcoding and conference, but not for TDM.
- Vivek
01-06-2017 09:53 AM
Hi Vivek,
Thanks for the fast reply!! I appreciate it. When trying to configure the dspfarm profile for Transcoding and conferencing, I came across an error.
Unfortunately, I don't recall the error output, however I will revisit that DSP profile error and post it shortly. Do you know if there is something specifically needed configuration wise?
Thank you,
-Diana
04-24-2018 02:27 AM
I have the same problem please see below:
E1 0/1/0: No DSP resources to configure voice feature
but when I go to show inventory it shows me the below
NAME: "Chassis", DESCR: "Cisco ISR4321 Chassis"
PID: ISR4321/K9 , VID: V04, SN: FDO2141A0P8
NAME: "Power Supply Module 0", DESCR: "110W AC Power Supply for Cisco ISR 4320"
PID: PWR-4320-AC , VID: , SN:
NAME: "Fan Tray", DESCR: "Cisco ISR4320 Fan Assembly"
PID: ACS-4320-FANASSY , VID: , SN:
NAME: "module 0", DESCR: "Cisco ISR4321 Built-In NIM controller"
PID: ISR4321/K9 , VID: , SN:
NAME: "NIM subslot 0/1", DESCR: "NIM-1CE1T1-PRI - T1/E1 Serial Module"
PID: NIM-1CE1T1-PRI , VID: V04, SN: FOC22054J7V
PID: PVDM4-32 , VID: V02, SN: FOC21374RYF
NAME: "NIM subslot 0/0", DESCR: "Front Panel 2 ports Gigabitethernet Module"
PID: ISR4321-2x1GE , VID: V01, SN: JAB092709EL
NAME: "module R0", DESCR: "Cisco ISR4321 Route Processor"
PID: ISR4321/K9 , VID: V04, SN: FDO213720SJ
NAME: "module F0", DESCR: "Cisco ISR4321 Forwarding Processor"
Please help
Thank you,
04-24-2018 06:14 AM
