Web Security
Cisco CyberSecurity
Hello,I don't understand how can I use transparent mode using L4 switch (it's load-balancer, right?). I'm friendly with L4 switches, even though I can not imagine the topology and data flow. I have two WSA boxes and I need configure active-backup mod...
Hi, currently we are using umbrella roaming clients across 3000 roaming user laptops. Now we need to upgrade the client to Cisco Secure Client.How the bulk upgrades can be done across roaming user laptops
manvik by Level 3
  • 157 Views
  • 4 replies
Hi guys,I have two servers on the same subnet which test curl a destination (cisco.com) via the WSA Proxy.The first one works correctly and I see in the logs:TCP_MISS/200 93202 CONNECT tunnel://www.cisco.com:443/=> CONNECTThe second one does not work...
cisco.13 by Level 1
  • 143 Views
  • 1 replies
Hi,I encountered an issue when attempting to access my website. I received an alert from Cisco Umbrella stating that "this site is blocked due to a phishing threat."I do not use Cisco Umbrella services. Why am I seeing this alert?Why has Cisco flagge...
Hello Team, We have Cisco WSA S695 Appliance and previously we were using decryption for all traffic due to which we faced the high proxy CPU utilization. Now we're using a decryption policy for certain traffic in which we decrypt some predefined cat...
Dear Cisco,Re: https://www.eib.edu.au | PhishTankOVERVIEW:Have been desperately trying to get a client's (Australian Gov't Registered Training College) domain name reclassified by PhishTank for approximately 10-months, without success. Thankfully, yo...
Hello community,  Is it a best practice to configure dedicated real IP address on P2 port on cisco WSA or we should use NAT ? If it is OK to dedicate real IP address, what are the security protections that can be enabled on Cisco WSA ?   Thank you!
Hi,I'm having trouble with accessing www.linkedin.comThe symptoms are that the page is not displaying correctly. Only links appear on the left hand side of the page. I remember facebook having issues rendering pages incorrectly a while ago.Because th...
jonweaver by Level 1
  • 24816 Views
  • 14 replies
Estoy intentando instalar la maquina virtual del curso para realizar la practica de laboratorio pero no he podido instalarla por que no encuentro la imagen iso. me pueden ayudar les agradezco mucho toda su colaboración.
Top Solution Authors
