11-20-2015 05:47 AM - edited 03-17-2019 04:59 AM
External callers are getting either busy signals or the phone line goes dead after 3 seconds. I have contacted our T1 provider but they believe the problem is within our CME system. I am not sure where to start troubleshooting this problem. Any suggestions?
11-20-2015 05:56 AM
You can start by posting your configuration and letting us know what trunk type you have.
Also, are outbound calls working?
11-20-2015 06:36 AM
We are using the Cisco Unified Communications Manager Express. Software version is 15.2/CME 9.0. with 2 PRI trunk lines. Outbound calls work fine.
11-20-2015 10:05 AM
Can you please make a test call run below debugs. also i see you have bunch of SIP and SCCP phone. are you calling to SIP from outside or SCCP one.
Debug isdn q931
debug voice ccapi inout
Br,
Nadeem Ahmed
11-20-2015 11:20 AM
I am using a cell phone to call into the main number. It should go into an automated attendent but it gives three beeps and then dead. I am not sure how to capture the debug. I turned it on but when I call I do not get any information. Can you help me with the debug.
11-20-2015 12:30 PM
are you able to call the 'External Callers', in other words, the outbound calls are OK?
As Nadeem Ahmed already described ... use the following commands in the CME and after that make an inbound call:
#terminal monitor
#debug voice ccapi inout
Hope this helps
11-20-2015 12:41 PM
Seems like you are using Hunting once the call land on your AA pilot ? Please confirm the what is HUNT GROUP PILOT NUMBER/AA number?
as mentioned above by Marcelo, please collect the debugs
Br,
Nadeem
11-20-2015 12:55 PM
I am using a hunt group
voice hunt-group 8 parallel
final 1458
list 1460,1465,1466,1452,1458,1454,1459,1449,1456
timeout 15
pilot 1467
I just ran the debug commands and called in and now the calls are going through. I have tried 14 times and have success each time. Most employees have gone home so perhaps no one is on the system?
Do you think that the system can't handle the call volume?
11-20-2015 02:31 PM
not sure if its happening only in office hours when there is high traffic could be one of the reason. But only logs can reveal.
Br,
Nadeem
PS: Please rate all useful post.
11-20-2015 02:51 PM
Thanks Nadeem Ahmed -
You have been very helpful - I will run the debug on Monday to pull the logs when there are people on the system.
11-20-2015 12:53 PM
Thanks for the help Marcelo - I was missing the terminal monitor command.
11-20-2015 06:42 AM
Do you think I am loosing connectivity to the Call Manager? IF I run "no mgcp" and then "mgcp" do you think that would fix it?
11-20-2015 07:14 AM
If you are using CME there is no MGCP.
Please post your CME config (show run) and "debug isdn q931" for the unsuccessful call.
11-20-2015 08:12 AM
