Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1915148members
1216012discussions
Community Activity
ASA in Firepower 2k
Hello Guy, Do anyone know how to check the existing the config-register on the ASA firewall please.when one of my HA firewalls reboots it goes to ROMON mode and I have to manually do boot to boot it up.How can i solve this issue please?I'm using ASA ...
AnyConnect RADIUS authentication issues
Hi Guys,We're having issues with our RADIUS authentication. We just keep getting login failed when trying to connect to our VPN. We've run an authentication test in ASDM and that works fine so not sure where our issue lies. I've pulled out our config...
Upgrade ISSU C6807-XL-6T same train release
Hi all I know that upgrade a relase in ISSU mode on WS-C6807-XL-6T device is not advisable.Anyway, My question is: if the upgrade is done inside the same release train could we have problem ? for example:from 15.5(1)SY8 to 15.5.1-SY12orfrom 15.5(1)SY...
marzi by Level 1
  • 10 Views
  • 1 replies
how to see the traffic rate under the interface vlan in NX-OS
how can we determine how much traffic passes through the interface vlan in the Nexus switches,the command (show interface vlan ) doesn't give the needed same as the catalyst,also, (show interface vlan counter) the values we can't read!
Sudqi by Level 1
  • 63 Views
  • 3 replies
  • 1 Helpful votes
Intégration de Cisco DUO avec Safeguard
 Bonjour à tous, Je suis sur un projet d'intégration de Cisco DUO pour une banque libanaise, j'ai déjà réussi à configurer le MFA pour fortigate SSL VPN, maintenant j'ai un problème pour configurer le MFA pour une solution PAM qui est "Safeguard for ...
msalhi by Level 1
  • 79 Views
  • 5 replies
Forward Broadcast
Hello,I have subnet like this :My pc under vlan 100 (192.168.100.0/24)My NAS under vlan 150 (192.168.150.0/24)Actually when the nas and pc located under same subnet, I can discovery the nas from my laptop using vendor utility, but can't discover when...
hs08 by Spotlight
  • 78 Views
  • 4 replies
DNA. Generate CSR from GUI
I try to generate CSR through GUI - System setting -> System Certificates -> Generate new CSR, but I get error - "The common name does not contain a valid IP address or Domain Name" but maglev cluster network display shows that cluster_hostname the s...
dijix1990 by VIP
  • 2192 Views
  • 18 replies
  • 1 Helpful votes
NAT64 sending an AAAA record instead of an A record on to IPv4-LAN
Here is the situation:                                             (IPv6-LAN) *   (IPv4-LAN)                                                               *                                                               *                              ...
