INSTALLING CUPS
kennedymacharia
I an trying to install this ova file cup_8.6.2_vmv7_v1.1 in vmware 6.0 but when I run it I get an error "missing operating system" is there something else that I should add
Manish Gogna
VMware 6.0 is not supported for this version. Please check the following
http://docwiki.cisco.com/wiki/Virtualization_for_Cisco_Unified_Presence#Version_8.6.282.29
The max esxi version you can go with CUPS 8.6.2 is ESXi 5.0
Manish
- Do rate helpful posts -
10 Replies 10
Manish Gogna
Manish
hi,
I have downgraded esxi to 5.0 but still not working is there anything else
Are you still getting the same error?
Manish
yes
Are you installing it on ucs or some other server?
If the ISO is already loaded to the VM, simply hit enter.
java
if this helps, please rate
you mean I should still have an iso image for this I deployed a virtual wireless controller with just an ova file and I thought this was like that . I am trying to set up a lab for CCIE collaboration. I have the cucm set up just missing cups and I dont have the iso image for it. Can I get a trial one from cisco? thank you
OVA just provides the settings for the application that needs to be installed. A bootable ISO is needed for the install. If this is the first time you are trying to create a VM and install a UC application you can refer one of the numerous videos on youtube for UC app install on a VM.
Manish
Yeah, for some applications, you should be able to tell a small file like the OVA from CUPS, which is very small, would not be the whole app, just the VM specs.
You can only get bootable images via PUT with a valid sales order.
If you're with a partner, you could buy the NFR kit, but I'm not sure they're selling still one for 8.x
java
ova file cup_8.6.2_vmv7_v1.1 this one is simply an OVA to create the Virtual Machine and after deploying this, you should be able to see one VM created. After this, you also need a bootable ISO for Presence server as well in your datastore for the installation to go through.
Deepak
