Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1919429members
1223734discussions
Community Activity
C9800 wlc Mgmtuser encrypt password
hi,the mgmtuser username password defined in my AP join policy show in clear text and cannot be encrypted.when i exe the command,mgmtuser username admin password 8 mypass123 secret 8 mysecret123always get error %password encryption failed: possible m...
Message Filter
I am needing to make a filter that will modify the header. The rule should defer processing until the end of the message.Can anyone advise if this is possible?Thanks!
Replacing Juniper GWs with Cisco
Hello Everyone. I am working on replacing juniper GW(production)switches with C9500’s. Those junipers are in active standby.My approach is pre-stage cisco switches copy configs from juniper to cisco. Here one question is juniper GWs are using vrrp fo...
clearance required for 9200CX
Hello Bro,I am looking at the rack mount information about 9200CX, but could not find the clearance it may require to dissipate the heat from the switch. Does anybody share if the switches can be stacked tightly one on top of the other?Much appreciat...
mcmib by Level 1
  • 177 Views
  • 4 replies
OID to check for active multicast groups?
As the title says, I'm trying to figure out if there is an OID/MIB I can poll that will return active multicast groups. It was presented to me that a team deploys media encoders that initiate the group and it would be quicker for the team to troubles...
KGrev by Level 4
  • 31 Views
  • 0 replies
Reports and Exports for FMC/FTD
Is it possible for the FMC to run a report to indicate what rules are inactive/disabled? What about reporting what objects are not being used?I know beside various items there is a "report" icon, or "export to csv" but this isn't giving me the info I...
aci_rest ansible and token APIC-cookie
 Is it possible using the ansible aci modules to login once and get the token and pass the cookie on subsequent aci_rest tasks? The goal is to avoid having to login and logoff with userid/password on aci_rest calls that have loops.  Is this possible?
cyberpea by Level 1
  • 79 Views
  • 1 replies
Date for CML 2.7 release?
The release-notes for CML 2.7 beta has been released, but there is no mention of when the regular release will happen. Is there any timeline for when we can expect 2.7 to enter general availability?
Torbjørn by Spotlight
  • 693 Views
  • 3 replies
ISE device admin Licnese
Hello I want to implement ISE in a network. Right now I want device administration TACACS to use, moreover; I want perpetual licenses.Do I need R-ISE-VMC-K9= License?Do I need a Device administration license (L-ISE-TACACS-ND=)?OR do I need both?I hav...
infome by Level 1
  • 141 Views
  • 6 replies
How to create webex control hub admin account?
May I know how webex control hub admin account created with organization? what is the procedure? I have customer with no webex control hub account and need to implement cloud based codec for MS teams.codec have cloud based license. but how to registe...
