QoS for Voice
leandroklazen
I am trying to do QoS for Voice traffic.
I need some help with the config, this is what I have so far.
class-map match-all VOICE
match dscp ef
class-map match-all SIGNALING
match dscp cs3
policy-map WAN-EDGE
class VOICE
priority percent 1
class SIGNALING
priority percent 1
Will this be enought to mark the Voice traffic and prioritize it should the link run into congestion?
your class map doesn't mark voip traffic but it uses the existing one.
If you want remark or override existing mark you can use the below config:
access-list 103 remark IPPHONE
access-list 103 permit ip host 10.25.100.85 any
! adjust acl on your needs
class-map match-all voip
match access-group 103
policy-map voip
class voip
priority percent 20
class class-default
fair-queue
and so apply the policy to the wan interface
interface FastEthernet0/0
service-policy output voip
Regards.
