Does Nexus 5672UP support GLC-T?
We are terminating the CE connection directly at 5672 over Copper Gig connection. Do you know whether nexus 5672up can support the 1GIG GLC-T?
thanks,
Ramesh
6 Replies 6
Reza Sharifi
The compatibility sheet (see below link) does not list the 5600 series for supporting GLC-T.
http://www.cisco.com/c/en/us/td/docs/interfaces_modules/transceiver_modules/compatibility/matrix/GE_Tx_Matrix.html
Hello Reza,
I think it supports. Please take a look the link below and give your feedback.
"Table 8.       Cisco Nexus 5600 Platform 1 and 10 Gigabit Ethernet SFP and SFP+ Transceiver Support Matrix"
http://www.cisco.com/c/en/us/products/collateral/switches/nexus-5624q-switch/datasheet-c78-733100.html
res,
Masoud
Hi Masoud,
You are correct.  It does support it. +5.
Thanks for pointing that out.
Reza
Thanks for the rating. 5+ from me as well.
Masoud
I just installed the GLC-T sfp into Cisco 5672 Nexus switch and I'm receiving an invalid sfp if possible could someone provide some insight on this issue
 just set "speed 1000" on port and get result :)
