11-25-2015 12:49 PM - edited 03-17-2019 05:01 AM
Hi All,
I am trying to import an audio WAV file for a particular mailbox through play/Record >>Option>> Open File. It is runnning fine when i play using Use computer on unity connection page but when i am trying end user number and call get forwarded to voice mail it does not play the wav file which has been imported.
Please assit.
Hari
Solved! Go to Solution.
12-22-2015 02:06 PM
If you continue to have issue with built in java player, try Audiotext Manager for Connection. This is much better tool for CUCX and it's free.
http://www.ciscounitytools.com/Applications/CxN/ATM/ATM.html
11-25-2015 02:06 PM
In CUCX, If you go to the user in question , EDIT>Greetings does it say "recording" at the standard greeting? In other words is there an indication that the WAV file you uploaded has been marked as recorded?
11-25-2015 04:51 PM
Hi Dennis,
Thanks for you response.
I followed the process mentioed above but its giving error when i am trying to save the greeting.
Its showing as Failed to Record name.
Please suggest
Thanks _
Hari
11-25-2015 05:32 PM
Check your Java version is compatible, like in this doc:
If that's not your version, you can find the similar doc for other versions in the main CUC documentation page, or searching cisco.com
12-22-2015 01:42 PM
Thanks to All.
12-22-2015 02:06 PM
11-25-2015 07:02 PM
It's like Jaime says, related to Java version, work around is to record the name first and then upload the wav file to the greeting. In general I found firefox works best with the recording applet.
