Showing results forĀ
Search instead forĀ
Did you mean:Ā
Urgent *** csacs-5-base-lic ****
Gaurav Singh
Dear All,
How many end points can support on csacs-5-base-lic?
Gaurav
If you are talking about cisco secure access controll system then chick the attachment. If not, please clarify what you mean by csacs-5.
5 Replies 5
saif musa
Level 4
Level 4
Chick the  link below, hope it helps..
http://www.cisco.com/c/en/us/products/collateral/security/secure-access-control-system/bulletin-c25-732915.html
HI Saif,
Thanks for your quick response.
 I am unable to find details about csacs-5-base-lic.
Gaurav
HI,
Thanks for the reply!
I got the answer.
Gaurav
Please click on correct answer to close this discussion and rate the post so other people here can make use of the solution.
