11-27-2015 02:12 PM - edited 03-08-2019 02:52 AM
Hi All,
I need to set up 10 or so switches in my network with 8 different vlans. I've connected them via Fiber as the runs are longer than the ethernet standard.
The issue i'm having is getting DHCP to work from our corporate vlan which is on a different (vlan) subnet than the other 9 switches. I want DHCP to be handed out from a windows DHCP server and i've set up all the vlan's with the IP helper address of the DHCP server IP that is on our corp vlan.
The switches are connected via trunk and i've also ensured that all the vlans are allowed through the trunk. Is there something i'm missing?
If I add the port (switchport access vlan 2) to one of the vlans that the DHCP server is connected to, the DHCP will work but thats only for one vlan. How can i get DHCP working for all the vlans?
11-27-2015 03:12 PM
You are saying that you have already implemented IP helper address. Did you encounter any proplem?
For each VLAN you have a corresponding interface VLAN in your L3 switch so you only need to set this command only on your L3 interfaces.
"IP helper-address [ DHCP server ip address]. For interface VLAN 2, you do not need to set this command.
As an example,
int vlan 2
des DHCP server
ip address 192.168.2.1 255.255.255.0
int vlan 3
des Client group 1
ip address 192.168.3.1 255.255.255.0
ip helper-address 192.168.2.2 [DHCP server IP]
int vlan 4
des Client group 2
ip address 192.168.4.1 255.255.255.0
and so on
Please let me know if I understood your question correctly
Masoud
11-27-2015 03:37 PM
I've already set the Ip helper-address but the nodes on the network are not receiving DHCP from the DHCP server on the corp network that is on the 192.168.0.0 network (vlan 10)
interface Vlan2
ip address 192.168.50.1 255.255.255.0
ip helper-address 192.168.0.10
interface Vlan3
ip address 192.168.51.1 255.255.255.0
interface Vlan4
ip address 192.168.52.1 255.255.255.0
interface Vlan5
ip address 192.168.54.1 255.255.255.0
interface Vlan7
ip address 192.168.55.1 255.255.255.0
interface Vlan10
ip address 192.168.0.1 255.255.255.0
interface Vlan16
ip address 192.168.56.1 255.255.255.0
11-27-2015 03:53 PM
Can you ping DHCP server with the source of for example 192.168.51.1 ?
some thing like this
ping 192.168.0.10 source 192.168.51.1 [on your L3 switch]
Set debug IP DHCP on you L3 switch while terminal moniter is on and try with one client. Please share the output.
Masoud
11-29-2015 01:11 PM
Thanks, I was able to figure out the channel-group wasn't configured properly causing the the port channel not to be up, up. Now its good. Thanks for the help!
11-29-2015 01:42 PM
It means your whole network was down.You had some computers connected to fa0/1 and fa0/2.
interface FastEthernet0/1 switchport access vlan 2
interface FastEthernet0/2 switchport access vlan 2
At least, they should have worked even your portchannel was down,
Masoud
11-29-2015 02:45 PM
I am glad your problem was solved.
Masoud
11-27-2015 03:58 PM
Adding to my previous command.
Which Vlan is associated with DHCP server?
You need to have something like this
int vlan X [ X in the same VLAN of your DHCP server]
des DHCP server
ip address 192.168.0.1 255.255.255.0 [ in the same range of you DHCP server]
11-27-2015 03:59 PM
here is the output of the debug
Sending 5, 100-byte ICMP Echos to 192.168.0.10, timeout is 2 seconds:
Packet sent with a source address of 192.168.51.1
IP: tableid=0, s=192.168.51.1 (local), d=192.168.0.10 (Vlan10), routed via RIB
IP: s=192.168.51.1 (local), d=192.168.0.10 (Vlan10), len 128, sending
IP: tableid=0, s=192.168.0.10 (Vlan10), d=192.168.51.1 (Vlan3), routed via RIB
IP: s=192.168.0.10 (Vlan10), d=192.168.51.1 (Vlan3), len 128, rcvd 3
Success rate is 0 percent (0/5)
VLAN 10 is where the DHCP server is
11-27-2015 04:14 PM
It means that switch does not see your DHCP server.
Try these and give me feedback
1-
If DHCP server is connected to fa0/1 then you need to config the port this way
interface fa0/1
switchport access vlan 10
Try to test direct connectivity
Ping 192.168.0.10 from DHCP sever (give me the result)
2- DHCP server must have gateway. Gateway must be 192.168.0.10
3-turn windows firewall off
and then try the previous ping
Masoud
11-28-2015 10:18 AM
11-28-2015 10:33 AM
Config looks good in terms of vlaning and DHCP relay.
interface Vlan10
description CORP
You do not need to set the above bold command.
Did you set gateway after my comment? or it was set before?
Can you ping ?
or
ping 192.168.0.10 source 192.168.50.1
And also do not forget windows firewall
Masoud
