I am configuring ASA5516 from scratch and trying to find out the current recommended versions.Could you please advise?Curretly:ASA Software Version: 9.8(2)Firepower Extensible Operating System Version: 2.2(2.52)Device Manager Version: 7.9(2)152
The content you are looking for has been archived. View related content below.
Hello, I deployed a new FTD 2110 on our company network and I'm seeing two different mac addresses on the switch port that the MGMT interface is connected to. I know that the one mac address is associated with the actual MGMT interface, but can anyon...
Hello, Does anyone know why the FMC/FTD would create an sf-storage folder on a Linux Server? When I configured the remote storage I tried to point it so that the backups are stored into a certain directory, however it created a separate folder within...
Has anyone tried to setup the Azure monitoring agent to on-premises Cisco devices so that they can be monitored on Azure? Please kindly let me know the procedure/necessary configuration if anyone has done this successfully.
Hello, I successfully set up/configured my first ASA device. I just purchased as second 5506 and am wondering about how compatible or incompatible the bkup configuration files I’ve saved from the first device are gonna be with the second ASA. It ment...
Hello everyone,I have a CISCO ASA 5555-X configured in multi-context mode and I want to monitor it via SNMP.However, I can't find the MIB files for this device.How can I get them?I don't have access to ftp://ftp.cisco.com/pub/mibs/supportlists/asa/as...
Hello everybody,the customer has the FMC rel. 7.2.5.1 and the Health Monitor shows the error messageSmart License MonitorSmart Agent is not registered with Smart Licensing CloudSmart License usage is out of compliancethis time for itself (see attache...
Hi there,Is Cisco Firepower have a Database for malware signature?When i check TECSEC-2599.pdf p77, the information is: FTD will first calculation the sha, and than send to FMC and FMC will check the Reputation from AMP Cloud.But i got another inform...
Hello everybody,our customer has FMCv rel. 7.2.5.1 and two Firepower 1120 in a HA running rel. 7.2.5.I have installed the FTD patch to rel. 7.2.5.1 successfully but the release that the FMCindicates is still 7.2.5 (see attached screen dump).Do you ha...
Hey allI have a Firepower 1010, I need to disable the SIP ALG on it, I have access to the Web Client and Telenet access to make changes, can someone give me an easy way to make these changes, I don't have the ASA Software that could access with.
Hi All, I configured anyconnect vpn in ASA and its working ok. I enabled ASDM access in inside interface (10.10.50.254). After connecting to VPN, i tried to ping and connect to ASDM on 10.10.50.254 but its not working and i get "routing failed to loc...
Hello!I´m using FMC 7.2.5.1 in Edge browser on a 1920x1080 screen with 75% zoom in the browser.When I open "Objects", the table of Network objects is shown.When I want to start flipping through the pages to find something (because "Why can´t I just s...
Hello everybody, our customer is using the FMCv rel. 7.2.5.1 and many FTDs.After de-register/re-register the FMC in the Smart Software Manger because another error message four devices (7.0.1 & 7.0.5) fourdevices show the error: Threat Data Updates o...
I have a Cisco FTD 2140 Secure Firewall that I am trying to build a route based IPSEC tunnel using VTI's. The vendor needs my proxy ID or encryption domain to be presented as a public IP address. So my WAN IP is obviously public but my internal netwo...
Hi I hope your doing well in our network infrastructure where we have Qualys to scan for vulnerabilities i can't find a solution for this certain vulnerability here are the details :Weak SSL/TLS Key Exchange impact an attacker with access to suffici...
Subject | Author | Posted |
04-19-2024 04:48 AM | ||
04-18-2024 11:50 PM | ||
04-18-2024 07:56 AM | ||
04-17-2024 12:36 PM | ||
04-17-2024 07:38 AM |
User | Count |
9 | |
7 | |
5 | |
4 | |
3 |
