11-30-2015 05:58 AM - edited 03-08-2019 02:53 AM
Hello
I'm trying to get logging of ip source guard drops working on a Cisco 6807 ios s2t54-ipservicesk9-mz.SPA.152-1.SY1a.bin.
Source guard is working perfectly but I can't get any traps/logs when there is a source guard drop (all snmp traps are enabled).
The output of "debug ip verify source packet" only shows the following:
Client has IP hardwired (Source Guard drops all traffic)
Nov 30 11:42:39.080: SW1: IP_SOURCE_GUARD: dhcp snooping vp state change, vlan: 79, port: GigabitEthernet104/1/0/1, add flag: 1.
Client uses DHCP (Source Guard permits all traffic)
Nov 30 11:43:35.276: SW1: IP_SOURCE_GUARD: dhcp snooping binding update, ip: 10.10.79.10, vlan: 79, port: GigabitEthernet104/1/0/1, mac: E8E0.B75A.775C, add flag: 1.
Some catalysts support smart logging with netflow for logging Source Guard and DHCP Snooping but the 6500/6800 doesn't seem to..
Is there a way to log source guard on 6500/6800?
Andy
11-30-2015 06:41 AM
Hello Andy,
You are right that some switches uses smart logging with netflow for source gaurd but have tried enabling the logging command.
switch-A(config)# logging level dhcp 6
switch-A(config)# logging logfile messages 6
switch-A(config)# logging event link-status default
Hope it Helps..
-GI
11-30-2015 08:19 AM
Thanks for the reply Ganesh.
I don't have these exact commands but current logging on the 6807 is :
Console logging: level informational, 7092 messages logged, xml disabled,
filtering disabled
Monitor logging: level debugging, 10907 messages logged, xml disabled,
filtering disabled
Logging to: tty1(6797)
Buffer logging: level informational, 6518 messages logged, xml disabled,
filtering disabled
Trap logging: level informational, 2142 message lines logged
I get dhcp snooping binding logs but no source guard. If i change logging to level 7 debug I see the basic source guard dhcp snooping updates shown in my original post but nothing regarding Source guard when it is actively filtering traffic.
The only logging options I have on the 6807 for "ip verify source" are for urpf and not source guard.
Andy
