12-01-2015 02:23 AM - edited 03-11-2019 11:58 PM
I have two image asa842-k8.bin and asa825-k8.bin. on my ASA But in the conf, it only have this commande :
boot system disk0:/asa842-k8.bin
Is the best practice to put the two boot image in the running-config or if the image in the running_config is not present and is the onlyone, it find automaticly the other image .bin ?
Pascal
Solved! Go to Solution.
12-01-2015 03:07 AM
The ASA will use the 1st Valid image to boot from if you have no bootvar configured. If you have a bootvar configured the ASA will use that image to boot. I would say the best is to hard code your boot variable in the startup-config. So that you force the boot from the Image you want.
12-01-2015 03:07 AM
12-01-2015 03:18 AM
Thanks ;-)
