12-01-2015 07:29 AM - edited 03-17-2019 05:04 AM
I am looking for the confirmation that DSP transcoding ressources on CUBE ISR G2 can be used by the CUCM in a scenario where the same DSPressources can be used as transcoder for the SIP trunk connection to the ISP ( CUBE acts as SBC too). Is there a possibility to split/dedicate the DSP ressources for the two different functions or I need to even dedicate a separate DSP gateway as a HW CUCM transcoder?
thanks.
Dan P
Solved! Go to Solution.
12-01-2015 08:11 AM
Hi Dan,
If you have enough DSP resources in CUBE to configure transcoding sessions, then you could add that trancoder in an MRG/MRGL and use it in the SIP trunk in CUCM.
Rajan
Please rate all useful posts
12-01-2015 08:11 AM
Hi Dan,
Rajan
