12-07-2015 02:18 AM - edited 03-19-2019 10:27 AM
Hi everybody,
According to http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/10x/supported_platforms/10xcucspl.html
If I select the OVA template for "Virtual Platform Overlay for up to 1,000 Users"
- Does it mean the user account and mailbox in CUC cannot exceed 1000 uesrs ?
If I have 1100 uesrs and very very low usage of voicemail, can I still using this "CUC 1000 user" OVA template?
Thanks in advance
Sam
Solved! Go to Solution.
12-07-2015 05:49 AM
As per my understanding , exceeding the number of users speciied in the OVA will not throw up any errors. However, since the product has been tested with certain parameters for optimum performance , exceeding the specified limit is not recommended and most likely will not be supported by TAC in case of any performance issues.
Manish
- Do rate helpful posts -
12-07-2015 06:07 AM
Manish is correct (+5), you could add as many users as you can (assuming sufficient licensing), however that would be considered un-supported. So, if you ran into any issues TAC might refuse assistance. Keep in mind that another limiting factor of specific OVA template is the supported number of voicemail ports.
I suggest you install the 5,000 user OVA.
12-07-2015 05:49 AM
Manish
12-07-2015 06:07 AM
12-07-2015 06:37 AM
I agree with Chris, go for the 5000 user OVA.
Manish
