Leo Laohoo Wed, 12/09/2015 - 10:10
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
How do you reset the 3925 to factory defaults?
There are several methods.  The "traditional" method is to log into the appliance and erase the config and the associated files.
The other method is to take advantage of the "Reset" button located at the back of the appliance.
kc123456789 Thu, 12/10/2015 - 12:17
Currently have not been able to log into the router so the need to reset. There is no reset button on the back of the router.
So still looking at how to reset a 3925 router.
Leo Laohoo Thu, 12/10/2015 - 17:05
  • Hall of Fame,
    2017 LAN, Wireless
Read THIS.
Hi there,
I have just pretended to reset a Cisco 2821 router, step by step so you can see my simple method of doing it. Same method i use on 3925 routers too. You will see doc attached and the highlighted commands in yellow. All you need to do is use a connect your router via console, you can use tera term which is pretty useful and simple console terminal to use.
regards,
Ben
