ISE upgrade issue 1.4 to 2.0
pemasirid
I was trying to upgrade ISE 1.4 (with patch 3) to ISE 2.0, I have downloaded the file from Cisco.com and copied to ISE disk:, however when it trying to unbundle the application (when we give the command "application upgrade prepare ise-upgradebundle-1.3.x-and-1.4.x-to-2.0.0.306.x86_64.tar.gz upgrade" it giving the error saying "% Unable to unbundle the package. It should be in tar.gz file format". the file downloaded is the same as it tried however I could see that hash value of MD5 was not the same where ISE was showing but when I verified the MD5 hash with the file I downloaded from Cisco.com is the same (mathching).
Here is the file I tried copied to the ISE - copy ftp://10.102.1.96/ise-upgradebundle-1.3.x-and-1.4.x-to-2.0.0.306.x86_64.tar.gz disk:\
Here its showing under repository name upgrade:
xxxxx/admin# show repository upgrade
ise-patchbundle-1.2.1.198-Auto6-131239.x86_64.tar.gz
ise-patchbundle-1.3.0.876-Auto2-130070.x86_64.gz
ise-patchbundle-1.4.0.253-Patch3-141133.x86_64.gz
Here is the error I am getting when trying to uncompressed by ISE;
xxxxx/admin# application upgrade prepare ise-upgradebundle-1.3.x-and-1.4.x-to-2.0.0.306.x86_64.tar.gz upgrade
Getting bundle to local machine...
md5: e4409b1b8ee3cdf134f985f3a776077f
sha256: 6084f5809d162cf694d76e93c982d691e5f7c95015c37cf739a4beaa7c6c94b8
% Please confirm above crypto hash matches what is posted on Cisco download site.
% Continue? Y/N [Y] ? Y
Unbundling Application Package...
Can someone please advise what is going wrong here or has anyone experienced this error.?
thanks in advance
7 Replies 7
nspasov
I had the same issue. Try:
1. Renaming the file and remove the .tar just .gz:
ise-upgradebundle-1.3.x-and-1.4.x-to-2.0.0.306.x86_64.gz
2. Try re-downloading the file
Thank you for rating helpful posts!
check to make sure that you have enough free space to run the upgrade bundle.
Hi All, For me it worked when I tried using sftp only. If you try ftp you will face this issue, could be some hashing/integrity error on file while copying ftp or some other method than sftp, but really not sure..
Bas van Delft
Encountering the same issue here.
- Hashes inconsistent
- filename not including .tar.
- error message "Unable the unbundle, it should be in tar.gz format.
Any luck with tackling this issue?
Solution: make sure the file is being copied fully.
The file I sent seemed to transfer successfully, but in the end it did not, the file size was only 1.2Gb. I did not receive errors along the way and assumed file transfer was successful.
I tried using ftp via windows explorer instead of ftp via 3comdaemon and it worked.
Jatin Katyal
So I have seen this issue twice, the error you are seeing is slightly misleading as the extension is correct - Internal defect. Also I read that when you downloaded the file, the MD5 checksum was correct however while transferring the file via FTP it got changed. This seems to little buggy behavior and I guess we need to raise. However for time being, try SFTP server to transfer the file to ISE local Disk.
~ Jatin
~Jatin
nohfendi1
Hello
The problem appears if directory in ftp server separate by space, I got changed it and work.
example : FTP SERVER change to FTP_Server
Please rate if helpfull
Thank You
