12-28-2015 10:51 AM - edited 03-17-2019 05:21 AM
12-28-2015 12:18 PM
Please follow the factory re-install and instruction given in this link, also is it fresh one do you have any backup ?
http://www.acumenitsupport.com/phone-systems/uc500-uc520-uc540-uc560-voicemail-cue-non-functional-and-inaccessible-service-module-is-trying-to-recover-from-resetshutdown-error-failed
12-28-2015 12:30 PM
It's giving me two options. Is a factory re-install necessary?
12-28-2015 01:17 PM
If your using as a fresh install then you can perform the factory re-install.
Br,
Nadeem
12-28-2015 02:58 PM
Thank you for the quick replies. I am extremely inexperienced with CCA/Cisco. Are these commands through the link supposed to be entered into CUE Exec commands window?
12-28-2015 03:08 PM
those needs to be run from CLI you need to console to CUE
login to CME/GW
service-module <ism0/0> session
Br,
nadeem
12-29-2015 05:42 AM
12-29-2015 05:42 AM
Actually after it seemed like everything was up and running, the same problem is now re-occurring. I went through the #2 step in the image above and it was working after this. Now when users hit the mailbox button, it is still doing the same thing. I will follow up.
01-10-2016 05:51 AM
In the end, the problem was with our 48 port switch not properly connecting to our UC. Once updating the software package on the UC as well as the firmware on our 48 port Cisco switch occurred, everything came back up and running. Only small configurations had to be made after this such as auto attendant options...
Thanks for all previous help.
01-10-2016 05:48 AM
yes
12-29-2015 08:07 AM
I've tried every step on this link and successfully did a factory reset. Still same problem. I don't know what the issue is. Everything seems to be up and running but its not. Please see below if you have a chance. Thanks for all the help so far...
