12-30-2015 12:36 PM - edited 03-05-2019 03:02 AM
Hello everyone. May be somebody can help me. I have router c892 (C890 Software (C890-UNIVERSALK9-M), Version 15.4(3)M4, RELEASE SOFTWARE (fc1)) with to uplinks: ISP1 (gi0) for Internet and ISP2 (fa8) to another network (10.0.0.0/8).
I tried to use PBR with match interface option, but no success (traffic from my Server 192.168.3.11 to the host 10.1.11.30 has been nated to the ISP1 WAN IP).
My config in attach (real internet IPs were changed).
Please help.
12-30-2015 03:58 PM
I don't really like that route notation for a normal Ethernet. Try changing:
ip route 10.0.0.0 255.0.0.0 FastEthernet8
to have a proper next hop of:
ip route 10.0.0.0 255.0.0.0 10.1.36.125
Is FastEthernet8 definitely up?
The other thought going through my mind is their is already a translation entry in the cache. Try doing a:
clear ip nat ranslation *
12-30-2015 04:00 PM
You could also try changing:
ip nat inside source list 102 pool to-bft overload
for:
ip nat inside source list 102 interface FastEthernet8 overload
and see if that has any impact. I'm not sure if using a pool with 1 single IP address equal to your interface IP is valid.
12-30-2015 11:51 PM
Hi guys! Thanks for your replies. I already found my mistake. It was ACL 102. I specified incorrect wildcard for subnet 10.0.0.0.
When I fixed ACL 102 everything worked. Here is correct config:
access-list 102 permit ip 192.168.3.0 0.0.0.255 10.0.0.0 0.255.255.255
access-list 102 deny ip any anyroute-map SDM_RMAP_TO_BFT permit 10
match ip address 102
match interface FastEthernet8
route-map SDM_RMAP_1 permit 10
match ip address 101
match interface GigabitEthernet0ip nat inside source route-map SDM_RMAP_1 interface GigabitEthernet0 overload
ip nat inside source route-map SDM_RMAP_TO_BFT interface FastEthernet8 overloadip route 10.0.0.0 255.0.0.0 10.1.36.125
ip route 0.0.0.0 0.0.0.0 194.194.194.1 permanent
