Management Plane Protection
Rowan Smith
Where has the configuration:
Router(config)# control-plane host
Router(config-cp-host)# management-interface FastEthernet 0/0 allow ssh snmp
gone in IOS 15.4?
This used to allow one to secure management plane traffic to specific interfaces so that the Cisco wouldn't listen on all interfaces for SSH etc traffic.
In IOS 15.4 I can't find an equivalent command and my VRFs are accepting SSH connections which the only way I can stop is with a ACL on each interface of the VRF.
The process is described here: http://www.cisco.com/c/en/us/support/docs/ip/access-lists/13608-21.html#anc33
That was it.  I just checked the Cisco Feature Navigator, and Management Plane Protection requires the security licence.  It is not part of IP Base or Data.
7 Replies 7
Philip D'Ath
What kind of device are you doing this on?
Hi.
It's a 2921 running 15.4(3)M4
I just trued this on a Cisco 2911 running 15.4(3)M2.  So I doesn't look like it is removed to me.
You're not using TACAS, role based cli, or anything else that might hide the commands from you?
cisco2911(config)#control-plane host
cisco2911(config-cp-host)#management-interface ?
Auto-Template Auto-Template interface
Dialer Dialer interface
Embedded-Service-Engine cisco embedded service engine module
FastEthernet FastEthernet IEEE 802.3
No, it's just a standard local username/password.   Command certainly isn't there for me...
rtr1#conf t
Enter configuration commands, one per line. End with CNTL/Z.
rtr1(config)#con
rtr1(config)#cont
rtr1(config)#control-plane host
rtr1(config-cp-host)#?
Control Plane host configuration commands:
exit Exit from control-plane host configuration mode
no Negate or set default values of a command
service-policy Configure QOS Service Policy
rtr1(config-cp-host)#management-interface ?
% Unrecognized command
% Invalid input detected at '^' marker.
rtr1(config-cp-host)#^Z
rtr1#sh ver
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.4(3)M4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Sun 27-Sep-15 06:34 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M6, RELEASE SOFTWARE (fc1)
rtr1 uptime is 10 hours, 1 minute
System returned to ROM by reload at 20:28:19 UTC Fri Jan 1 2016
System image file is "flash:c2900-universalk9-mz.SPA.154-3.M4.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2921/K9 (revision 1.0) with 487424K/36864K bytes of memory.
Processor board ID XXXXXXXXXX
3 Gigabit Ethernet interfaces
1 terminal line
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
254464K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device# PID SN
*1 CISCO2921/K9 XXXXXXXXX
Technology Package License Information for Module:'c2900'
Technology Technology-package Technology-package
Current Type Next reboot
ipbase ipbasek9 Permanent ipbasek9
security None None None
uc None None None
data datak9 RightToUse datak9
NtwkEss None None None
CollabPro None None None
I just tried that exact image (15.4(3)m4) on a 2911 and it worked fine.
I notice you have IP Base and Data, while the router I am testing is licenced for more features.
security securityk9 Permanent securityk9
uc uck9 Permanent uck9
data datak9 Permanent datak9
Let me check the CIsco feature navigator.
Thanks for your time.
